Ignition woes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Adub, Feb 13, 2003.
  1. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    Tried to instal the d#mn Crane HI6S box the other day and it wouldn't work. Coincidentally my alarm starts going on the fritz when the truck is on (connected to the ignition) even if the Crane is unhooked. It sounds to me like I am not getting enough voltage if it is tripping my alarm. Its pouring rain right now so I cant go check the voltage at the cool. Where could I be losing voltage at? The truck runs and starts fine, no cutting out or anything.
    AW
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    I really have no clue...just ditch the Crane box and go on down the road would be my suggestion......sorry.
  3. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    Crane box isnt hooked up, its just running stock now, but the ignition is still messed up.
    AW
  4. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    I have 12 volts across the gray coil connector with the ignition on and 0 volts across the black connector. Normal?
    Aaron
