Ignition
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Moose, Jun 10, 2005.
  1. Moose
    Moose 1/2 ton status
    1,062
    Glendale, Arizona
    Ok guys I am stuck. My wife's 89 I backed it up in the driveway to move somethings and shut it off. When I started it up and tried to put it in gear and it wouldn't go other thatn reverse. I thought it was tranny so I disconnected the lever and shifted the tranny fine. When I tried to shut it off the ignition would not shut off it is stuck on. I had to pull the fuse to get the motor too shut off. Any ideas why the ignition won't turn . Help. :confused:
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Ignition switch maybe
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    If the key goes to the "off" position, I would guess that the rod in the ignition switch on the column has come out, or the contacts in the switch are welded.
  4. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Happened to mine I just replaced the ignition switch and that cured it.
  5. Moose
    1,062
    Glendale, Arizona
    mxfireman you were right. Went to Checker got an ignition and bam it works. Thanks guys.
  6. mxfireman
    Dec 7, 2002
    2,480
    LHC, AZ
    Sweet, good deal man. When mine did that it scared the $h#t out of me. FYI I am on maternity leave right now with my wife I go back to work at the end of June I should have your T-shirt and I will ship it to you. :xmas:
  7. Moose
    1,062
    Glendale, Arizona
    Thanks man. So did you guys have the baby yet?
