Ignition
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bking, Jun 18, 2001.
  1. bking
    bking 1/2 ton status
    Jan 4, 2001
    176
    Alaska /Here from Ireland in Dec 2000
    My 85 was running sweet yesterday, this morning it won't start. There is normal battery power, but when I turn the key, nothing happens, no starter clicking, nothing......I've checked fuses and wiring, to the coil, alternator and starter, can't find anything wrong, could it be in the steering column, at the ignition cylinder? I'm guessing its a loose connection, what do you's think?
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Have you checked you battery connections? Take the cables off and throughly clean the connectorsand Posts/sidemounts. Then when you bolt them back on make sure you get them tight enough and have a good connection.
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://www.geocities.com/emmettology101>http://www.geocities.com/emmettology101</A>
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Run a jumper around the fusible link on the firewall and try it - you've got the exact symptoms of it blowing out/breaking.
    I'm so poor I can't even pay attention [​IMG]
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A>
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Another thing to try is hitting the starter with a hammer (read: universal Blazer tool) while someone trys to start it. But the problem could be in many places. Have someone try to start it and poke around with a test light to see where you have juice.
    '71 Blazer CST with alot of rust
  5. bking
    Jan 4, 2001
    176
    where on the firewall? what am I looking for?
  6. bking
    Jan 4, 2001
    176
    Could it be the starter solenoid? A hit with a stick did the trick, I had this problem ages ago, bought a new solenoid, but the tuck was ok again, so I've still the new solenoid in the garage, do you think thats the problem, the solenoid rather than the starter, (I hit them both with the stick) Now its the same, totally dead again.....I think I'll replace the solenoid anyway, whatcha think?
  7. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    It's a big, thick red or orange wire. There's a connector block mounted to the right hand side of the master cylinder (as if you were sitting in the rig), connected to the right hand side, you'll find it. Typically, they are about 8" long, and spliced on with a butt connector. Jump around it and give it a whirl.
  8. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I'd replace it definitely. If it's stuck, it's likely to get completely stuck soon.
