Igntion Help please
Discussion in 'Rocky Mountain Region' started by Hossbaby50, May 12, 2002.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Ok, got home from college and the truck won't start.
    I am not getting fire to the plugs. At first I thought the MSD box may have fried the stock coil. But I put in my new MSD Blaster SS coil and tried to start the truck. Still no fire.
    First question, what exactly needs to be hooked up to an exterior coil? Positive and Negative power, coil wire, anything else? (i have tried a hot lead from the battery to the coil on the positive side).
    Second what else beside the coil could cause the no start in the igniton system? My truck no longer has an igntion module because of the MSD box. The distributor cap & rotor are 2 months old.(MSD)
    My parents started my truck a couple weeks ago, but now it won't fire. It cranks, and I can hear fule go when I move the throttle cables.
    Also my truck has an MSD 6 offroad box, MSD blaster ss coil (not sure it is hooked up right), MSD cap & rotor, MSD wires.
    Thanks for any help.
    Harley
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Two things that I have seen go bad that wouldnt allow it to start is the pickup in the dist. went bad, or the piece under the coil in the HEI went bad(the piece with the spring and the rubber isolator around it). Check those and let me know how those look.
    Dan
  3. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    The spring and rubber isolater are in good shape. I replaced them both when I installed the cap & rotor during spring break. I also checked them today, and they looked ok. Another thing i forgot to mention was that I am changing from the incap coil to the external Blaster SS, and I am using the HEI dust cover from MSD to do this.
    I am sweating the program a little because I got to get this thing running so i can get to your place Wednesday. Thanks
    Harley
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have the new coil wired like this. The orange wire is on +, the black is on -, and the middle wire from the old coil is wired to a rad support ground point. Is this right?
  5. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Ohm the green and white wire...ie: the pick up coil...if its open your sunk until you replace it...had the same thing go out on me on the chalet with a 6AL box.
    Azblazer
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    How hard is it to replace your pickup coil. Me and my buddy ran hot wires to the coil, and bypassed the kill switch so it isn't those two things. So I am down to pickup module. I was reading the process of replacement in Chilton's but they were a little fuzzy. Do you have to remove the whole ditributor? How much does a pickup coil run? Thanks for your help.
