i'm a moron.
Discussion in 'The Lounge' started by ryan22re, Apr 5, 2006.
  1. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    yep it has been confirmed. spilled about 20-25 gallons of used diesel oil all over the concrete outside my work last night. then i spent the nest 7 hours cleaning it up. :doah: there is still a huge stain, probably 12x12 in area on the concrete. and its right on pretty much the main entrance. at least my boss is on vacation for the next couple of days. :crazy:
    anybody have any "safe" ways to remove oil stains from concrete? i got some "purple power" biodegradeable driveway cleaner, havent tried it yet.
    the simple grean driveway cleaner doesnt work on diesel oil. trust me i tried last night. with a pressure washer.
    man i feel dumb. :1zhelp:
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    cover the whole slab in Deisel, then the boss won't notice since it all looks the same:haha:
  3. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    i really thought about that last night.
  4. dyeager535
    26,982
    191
    Don't know about diesel, but a really good hot pressure washer removed the ATF, engine and gear oil stains from my neighbors concrete driveway. I imagine the heat had something to do with it's effectiveness, I really didn't expect it to come out as clean as it did.
    I figure since I put the stains there, it would be nice of me to remove them. :)
  5. muscle
    muscle 1/2 ton status
    May 28, 2000
    408
    Show Low, AZ
    yep hot water to a standard pressure washer. I use super clean first with a little water. scrub it with a broom. power wash it off
  6. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    So how do you get hot water to feed the pressure washer? Use the hot feed for the clothes washer? All my outside faucets are cold.
  7. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    they make pressure washers that heat the water.
    wish i had one.
  8. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    i plumbed hot and cold outside to heat my water, great degreaser.
    also maybe try, industreal streanght laqure thinner, or muriatic acid to clean it, only thing is the acid will really clean the drive way and make just that spot look clean
  9. muscle
    May 28, 2000
    408
    Show Low, AZ
    Muratic acid will etch the concrete finish. it basically eats away the top layer of cream leaving a sanded finish.
    Most hot water heaters have a hook up at the bottom to drain it with a hose. just run it into your pressure washer. :D
  10. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    yeah and it looks clean :D
  11. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,494
    1,198
    So Cal.
    try the easy off oven cleaner, everyonr knows that stuff cleans great. will take paint right off too. pour it on let it soak and scrub it with a push broom and rince with hot water.
  12. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    Yep, what he said.
    Also, "ZEP" brand cleaner works pretty damn well. Cleaned motor oil up with pressure washer and cold water.
  13. CustomChevy
    CustomChevy 1/2 ton status
    Jun 29, 2005
    4,328
    Kitchener, Ontario, Canada
    if your gunna use cleaner ... better do the whole area. no need for a giant clean spot :)
    and if noone knows about it ... or they will keep their mouths shut u can probably catch brownie points for a nice clean surface when the boss gets back.
  14. justwhatido
    justwhatido 1/2 ton status
    Apr 8, 2004
    1,037
    Mobile, AL
    Purple power degreaser/cleaner. Available at most auto parts stores. Spray it over the stain and let it soak in for an hour or so and then spray it off.
    Works on oil stains on my driveway.
    Fred
  15. gmcman7202
    gmcman7202 1/2 ton status
    Sep 19, 2005
    181
    The land of FIBS
    well the bottom valve is for draining the tank, since the cold has a down tube, so the cold sits at bottom, and the hot is at the top, heat rises, it will wont be that hot off the bottom, but it will get hot.
  16. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    just hook to the washing machine feed, I do it all the time, works great and hot water is the key... rinse it till you get the whole area warmed up, then pour every cleaner you can think of on and scrub, wait, scrub some more, keep it wet, scrub, rinse with your fresh load of hot water...
  17. gmcman7202
    Sep 19, 2005
    181
    The land of FIBS
    get the whole area warmed up.....keep it wet, rub, fresh load of hot..... use your mind now, doesnt sound to bad of a plan now does it?
  18. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    eh, i guess im out of the hot water so to speak. had the cleanup crew pressure wash it twice today before i came in. really didnt make a difference. lead tech said im cool. hear from my boss on monday i reckon.
    thanks for the responses, but it looks like its out of my hands now.
  19. fabjunkie
    Aug 23, 2005
    1,580
    Dallas Outskirts
    That's what I was worried about. That and there not being enough water pressure by just "draining" the tank. I guess since the laundry room is right next to the driveway, I'm in good shape.
  20. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Damn, my secret treatment for the misses is out... It's ok tho, I didn't say whether you rub clockwise or counter :wink1:
    Wasn't that a Seinfeld episode? Don't steal my move! :haha:
