I'm an Idiot: Dana60 brake install Help
Discussion in 'The Garage' started by mtnman210, May 24, 2006.
  1. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    I had some free time today so I thought I'd do something simple and get the 60 put together. Well I'm still stuck at step 1:doah:
    I can't figure out how the brake caliper brakets go among other things.
    first is this how they sit on the calipers. Am I right...reversed,wrong side,etc...
    What the heck is this little bolt for
    and do these have something to do with it? This is all I have--is it all of them or should I have another set for the other side. Or do these even go with the brakes?
    another angle
  2. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    Looks right to me. Those things are what will hold your caliper in place. They can be a real PITA installing. sometimes they go on the first try sometimes you can sit there and wiggle the caliper all you want. Some tips, get a hammer to pound those metal pieces in and make sure the holes are aligned and screw them in.
  3. ivie29
    ivie29 1/2 ton status
    Apr 26, 2006
    212
    gypsum, colorado
    If I remember right the spindle goes on before the caliper bracket, other than that everything looks good.
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    dont you have to put the axle together before you put the caliper on...???
  5. ivie29
    Apr 26, 2006
    212
    gypsum, colorado
    Of course the axle shafts will have to be installed before you get to the calipers and spindles but Im sure that you already know that.
  6. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    lol i did mine, and could probably do them in person, but over the net.... :S
  7. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    if it is a ford 60 the caliper bracket goes on first .
  8. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    Since I just replaced the inner seals in my D60 2 weeks ago, and will be doing it again on Saturday ($#@**#$), this is fresh in my mind. PM me if you want me to take some pictures, walk you through it on the phone, write it up or whatever...The long and short of it is that you get the axle shaft in, then the spindle, tehn the brake bracket, brake dust cover, rotor, hub, and the brake caliper (yes, you can pu tth ecaliper on a little earlier in the process). All I did was hold the caliper up, and slide in the two shims in together and then drive them in wiht a hammer NOTE - Take that bolt out of the bracket first!!! It takes about 30 minutes to go from where you are to wheel on and ready to go (if nothing breaks, strips, or I don't somehow hurt myself)
  9. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    yes I know the shafts have to go in first. I'm waiting on a set of 35spline outers so I'm just throwing the hubs on so I can get wheels on it and get it under the truck and out of the way. Thanks for the help I knew it was simple enough.
  10. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    1. Spindle
    2. Brack Caliper Bracket
    3. Rotor
    4. Wheel
  11. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    poyfect:thumb:
  12. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    The one on the right is broken. Change it out.
  13. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    I was wondering that. It doesn't look like it's a break but it didn't make sense that one had holes and one didn't. Any idea where I can get those.
  14. readymix
    May 30, 2004
    6,706
    26
    Try Highonda at PBB or Parts Mike
  15. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Are they included w/ loaded calipers? i need all the small brake parts. Ive dealt with doug a few times (highhonda) Great dude, hes who i got my 60 from. Even though i like dealing with him, id rather get them close.
  16. readymix
    May 30, 2004
    6,706
    26
    No idea:thinking::dunno:
  17. readymix
    May 30, 2004
    6,706
    26
    Raybestos part Number: 505519
  18. readymix
    May 30, 2004
    6,706
    26
    On second look, I may have been wrong about it being broken. Look up Raybestos part# 5556A. It shows it to look exactly like the one I thought was broken. I guess I have just never seen one like that
    Edit: Part Number: 5556A is .080 oversized so it would not directly apply unless your brackets were worn out. There is another part number for a non-oversized app though. Just don't have it handy.
  19. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    A little dielectric silicone grease goes a long way where the caliper slides on the keepers and the bracket. Use that specific grease b/c of it's waterproofness (Or nearly so) and it's ability to deal with ultra high temps. It's also what GM tells line mech's to use there.
