Im And Idiot And Need 14b Value Help!!!!
Discussion in 'The Garage' started by GotLabs, Dec 30, 2005.
  1. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Alright, after pulling my eyebrows out and searching I decided to ask this stupid question. I found a 14bff under a G30 van, it is complete. Is it worth 150$? I have to pull it for that price, the owner said he would cut it out for 50$ more. I know I have to change the spring perches and shock mounts but, This is the stuff that kills me I find this junk and then I dont know if its worth the money!!!!!!!!!!!!!!!!!!!:mad: :mad:
  2. j20m715
    j20m715 1/2 ton status
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    I would buy it if its in good shape.
    It is wider than a truck 14 bolt.
    It may have really high gears in it.
    Make sure its a full floater & not a semi floater
    Good luck
  3. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    well if it has the gears you want and if the carrier is open then it might be worth it. I know the van's 14ff go for alittle more than the standard width 14ff. if it dosen't have the gears are open carrier that you want I would pass on it and keep looking.
  4. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Dont but it, I may know where one is that you couldn buy tommarow cheaper, it wouldnt be locked and mayby 4.10's at best. But it should be under a hundred.
  5. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    I'd never pay $150USD for a 14bolt. Around here one can be had for $50-$100CAD out of a truck.
    $50 to torch it out is obscene. That alone should be an indication of highway robbery. With an oxy/ace torch you can have a rear diff out in about 90 seconds.
  6. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    got mine for free . and the complet van minus motor /trans. :D
  7. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    If it were me I'd send a PM to this guy...besides for $50 he could probably lay a charge on the van and turn it into confetti without touching the axle itself:D
  8. sapper
    Jul 11, 2001
    3,052
    NoVa
    How do you know I do charges???
  9. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    I have sold 14bolts for 150$ but they were delivered to the guys truck bed by me. I would say 150$ is top of the line for a drum braked, stock geared 14bolt. I don't think I would pay that because they are easily had for less with some leg work but if your time is worth more than your money than maybe it is worth it to you.
  10. resurrected_jimmy
    May 23, 2005
    2,241
    I am a cav scout and I was guessing by your screen name
  11. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I sell them for 150-200 all day long. It's the going price around here.
  12. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I've paid as much as $120 CDN for one in the correct ratio, correct perches, and shot brakes.
    I've traded one (4.10, 1-ton, good brakes) for a 3/4-ton 10-bolt w/4.10 & raised steering arm.
    Some of the 'low-brow' wrecking yards around here have falt-rate prices for axles.... usually ~$100-200.
