IM BAAACK!! and of course need help
Discussion in 'The Garage' started by CaveBlazin, May 9, 2005.
  1. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Ok here's the deal after letting my truck sit all winter with a BRAND new engine I go out to crank it up yesterday and she fired right up like a dream then reality hit and water started squirting from the side of the head or so it looks like the side of the head. So did the engine just have the gasket dry up and cause a leak out the side of the head? But the engine sure did sound good and seemed to not be mixing oil and water(was'nt a white mixture from the exhaust or chocolate milk from the oil). Any suggestions would be great. P.S. I graduate the Police academy in 6 weeks.....
  2. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    sounds like maybe a bad gasket right outa the box!
  3. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Sounds like head gasket, freeze plug or maybe a temp sensor hole that need a plugging
  4. tdcombs
    tdcombs Registered Member
    Apr 12, 2005
    98
    missouri
    Freeze plug would be my guess.
  5. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
    mine did that from the left sid of the motor it was a freeze plug that the gm dealer didnt put in with the crate motor i bought.
  6. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I hope you had antifreeze in it - I have seen blocks crack below and parallel to the head. Does it leak (while full) with the rad cap off?
    Freeze plugs should be called casting plugs :mad:
  7. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    I am pretty sure it is from where the head and block meet but It was dark out so I'll take another look. I did have coolant in it and it did not get hot on the gage. Im just gonna put a little insurance in it and replace the head gasket for the engines sake. I'll be back to member status hopefully soon depending on finances Im sure we all know that issue!!
  8. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Another thing is I need the part # for the Hydraulic clutch line, the line going from the tranny to the slave cylinder. If anyone can get that for me that would be GRRRRRREAT!!!!
  9. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Welcome back Spence! Good to hear from you!
  10. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Spence you were looking for this part last year. :grin:
  11. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Thats not a good thing is it :whistle:
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    expansion plugs :rolleyes:
  13. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Anyone got those part #'s????
  14. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Well tim is gone now, so hopefully someone else knows it. So have they given you trouble at the parts store? It's sad sometimes, their inability to look stuff up.
  15. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    TROUBLE, to them this part does not exist. What a bunch of crap!!!
  16. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Sounds like a bad block to start off with. I will give you 10 bucks for it and the truck. :grin::grin::grin::grin:
    Great to see your back. Give me a call sometime. My number hasn't changed, or atleast I don't think it has. When you all coming to visit?
  17. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    Clutch Shift Fork 15592270
    Clutch Fork Pivot Ball 15592268
    Hydraulic Hose (master to slave cylinder) 15537760
    Flywheel, 168-tooth, Steel 10105832
    Pilot Bushing 14061685
    Throw-Out Bearing 15613306
    Dust Shield 15521936
    Bellhousing 15530202
    Slave Cylinder 15615868
    Master Cylinder 15615867
    Clutch Pedal 15592273
    These part numbers were found using the search feature.
  18. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Wow was that in a members only area cause I tried that DOAH!! I need to get my membership activated sometime this millenium.
  19. ratzila
    Aug 9, 2003
    691
    Mobile,Al
    It was in the tech articles section.
  20. camarine
    camarine Registered Member
    May 27, 2002
    78
    NC
    I will beat it and give you 50 bucks for that truck. I seen it in person once, when the paint was all nice and purty. Is it still that purty?
