I'm building a beater truck....AND YOU GUYS GET TO DECIDE HOW IT'S BUILT!!!
Discussion in 'The Garage' started by BigOrange90Jimmy, Sep 26, 2004.
  1. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    I\'m building a beater truck....AND YOU GUYS GET TO DECIDE HOW IT\'S BUILT!!!
    ...and i'm using what i have laying in the yard. it consists of a 74 4x4 K20, an 86 4x2 C10, whats left of an 87 4x4 K5, and a lot of scrap metal and parts. here's the cool part: YOU GUYS GET TO DECIDE HOW I BUILD IT!!!
    Remember, EXTREMELY low buck is what I'm shooting for. However, I am willing to buy some parts, as long as it's reasonable and doesn't cost much. So post up fellas and help me get this ball rolling. I want to make a helluva one-off truck. If it's ugly, WHO CARES?!?! It's gonna get beat to hell and back anyway! /forums/images/graemlins/peace.gif
    /forums/images/graemlins/screwy.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/screwy.gif
  2. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Re: I\'m building a beater truck....AND YOU GUYS GET TO DECIDE HOW IT\'S BUILT!!!
    Take as many engines as you have, get them all running and connect them to the same transfer case with a chain/cog system..... /forums/images/graemlins/peace.gif /forums/images/graemlins/rotfl.gif
  3. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    let's see....a ford 2.3 4 cyl, a couple of old farm truck straight 6's, a 350, a 4.3 carb'd V6, and a 5.7L diesel out of a Cadillac.
    I'm guessing it'd put out about 11 HP and 1032874098172 ft. lbs of torque (all from the Cadillac convert diesel)
  4. RustBuket
    Feb 21, 2003
    1,618
    Do it!!! /forums/images/graemlins/rotfl.gif
  5. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    Assuming the ratio is favorable, I would start by putting the 8 lugs from the 74 under the K5 and build on that...
  6. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    If you don't care what it looks like and don't intend on driving it on the road, start by dumping all the sheetmetal on the blazer chassis, swap some axles around and spend some money on tubing.
  7. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    we need pictures to decided /forums/images/graemlins/thinking.gif /forums/images/graemlins/deal.gif /forums/images/graemlins/whistling.gif
  8. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    4.10's in the 3/4 ton diffs. let me ask why the blazer chassis though?
    pictures will be on the way soon...
  9. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Better wheelbase than the K20. The frames are also slightly more rigid. /forums/images/graemlins/thumb.gif
  10. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    In addition to what truknutz said, this is Coloarado<font color="blue">K5</font> /forums/images/graemlins/smile.gif
  11. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    ...there won't be much of a k5 left if that's what WE build.
    COME ON GUYS!!! POST IT UP!
  12. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Build it like this /forums/images/graemlins/thumb.gif
  13. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    crap here is the link.
    Austink5
  14. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I like the frame truck idea. Always kinda wanted one myself. /forums/images/graemlins/waytogo.gif
  15. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    here's a pic of the 74 k20
  16. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    WOW! That K20 is in awesome shape! /forums/images/graemlins/rotfl.gif I saw strip the K20 down to the running gear and frame, weld some tube on it, mild lift...maybe, some decent sized tires, and wheel the piss out of it!
    Kris
  17. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    aight some more rules for ya. there can be little to no tube work required because i have no access to a bender or a mig or tig welder. if it's gotta be done, it's gonna be the good ol stick welder.
    I'M NOT HEARING ENOUGH OUT OF YOU GUYS! GET CRAZY WITH IT!!!
  18. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    can i help build it? /forums/images/graemlins/grin.gif
  19. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    sure if you feel like driving down here
  20. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    Take the K5 frame... swap the K20 cab (if its a regular cab) onto it... then use some old fenders, whatever isn't rusting apart, angle them in to narrow the front end (ala Sandman) and sawzall the hell out of them so they are out of the way of the tires. If ya have something you can throw together for a flatbed, go that route and have it narrowed in the rear too. Make the flatbed only as long as the rear spring hangers, cheaper for steel that way and your departure angle will also rocks. Definitely use the axles from the K20, 4.10s / 3/4ton are a good place to start. Take the 52" springs from the back of the K5, clean em up and put em in front of the new rig... take the longest springs off the other two rigs, whatever they are, and swap em into the rear suspension of the K5.
    all i can think of for now... whatever you do, take a chit load of pics and document the whole experience. /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
    j
