I'm buying a D60 today - what do I look for?
Discussion in 'The Garage' started by Paxx, Aug 23, 2004.
  1. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    I\'m buying a D60 today - what do I look for?
    Ok I'm going to check out a D60 I found on a local board today. Its a 1986, is this a good year? I know that there were some years better than others.
    So other than pulling the cover and checking the gears for missing or chipped teeth what else should I check it for? Thnx guys
    ~Max
  2. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    Re: I\'m buying a D60 today - what do I look for?
    1985 and up are the "beter" years because the inner axles "neck up" instead of "neck down". make sure the hubs work properly...
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    if it is a dodge axle, it will have external hubs. see if you can get the spring plates with it.
  4. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    Depending on what year it is has a factor in that. The 90-93 Dodge version's have internal hubs like the GM 60's have.
  5. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    What about the miltary CUCV type axles...are these neck up style or does it also vary by the year??
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Actually either 79 or 80 were the last years for the neck down axles.
    Plan to replace the king pin springs and bushings if they have never been done. If 4wd was not used much there might be a little surface rust in the pumpkin but it's nothing to worry about.
  7. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    I forgot to mention that it is a GM D60 /forums/images/graemlins/thumb.gif
  8. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    Spring plates... don't forget the spring plates!
  9. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    Oh and what is the best way to check the hubs? lock em in and try to turn the pinion yoke?
    sorry for the newb questions
  10. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Just thought I'd ask and since you (Wayne) a replying to this you would know best cause the D60/14B I have came from "TheGeneral's" truck and he got them from you. I for sure have to do the kingpins...she shakes like a MOFO and one of the seals is leaking out the driver side. That all gets done when I do the detroit in November /forums/images/graemlins/peace.gif
  11. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    what about spring plates? I know that the only thing he says is wrong with the axle is the driver side spring pad has been cut off. /forums/images/graemlins/dunno.gif Didn't think that was anything major though.
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Don't worry about the driver's side, that's the easy one to get (you could even use a rear spring plate from a 14 ff equipped truck to replace that).
    It's the passenger side on that takes the bolts/studs that you need.
  13. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    ok thats good, I thought it would be all right.
  14. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    how much are they asking for it? I have one from an 85 with locking hubs- 4.11 ratio for 850.00 it is a SRW type and not the dually type
  15. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    He wants $1100can for it which at todays rate comes to $841.31us dollars /forums/images/graemlins/grin.gif
  16. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    I was talking about the u-bolt plates that go on top of the springs. They're different from 1/2 & 3/4 ton and can be expensive to buy. /forums/images/graemlins/thumb.gif
  17. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    ahh I see, good point I wouldn't have thought of that. /forums/images/graemlins/waytogo.gif Thanks
    As far as checking the hubs can someone give me a clue on the best way to do this?
  18. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    You can make spring plates easy enough right????
  19. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Theres always somebody on ebay selling them for 30.00
  20. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    dont worry about spring plates, you can always have peeps here on ck5 make em for ya. IMO, definitely not a "deal breaker" on a good used D60...
    j
