I'm doing rigth or not?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazingItaly, Aug 15, 2002.
  1. BlazingItaly
    BlazingItaly Registered Member
    Apr 7, 2000
    Milan Italy
    I\'m doing rigth or not?
    I'm still on the field for my engine.
    I've started to disassembly the accessories prior to remove the whole engine to do a major overhaul.
    Everythings seems to work fine (at least until the day that the engine blows).
    I'm checking the accessories trying to understand what to keep and what to throw. Any parts has evident sign of usage. There is a little rust in the outgoing neck of water pump, there a lot of moisture on steering pump(don't know if it comes from the pump or from hoses). Of course any vacuum hose must be replaced, as well of belts, sparks plugs and cables, rotor and cap.
    I'm budget minded, so if I can save some parts it would be great.
    Any advice will be appriciated.
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    Pocatello, ID
    Re: I\'m doing rigth or not?
    I would get a new water pump but reuse everything else on the accesories. That is normally the only thing that I replace.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    Northeast Nevada
    Yeah. A new water pump/thermostat is a must on a new engine. Also look at the radiator.
    . If there is any corrosion in it take it to a radiator shop and have it cleaned out.
    I also like to replace the starter wheen installing a new engine. The higher compression of a new engine will take its toll on a old worn out starter.
    Rebuild the carb or get a new/rebuilt one is always a good idea.
    I would not worry about the power steering pump unless there is a major problem with it.
