I'm done too..1980 K5 FOR SALE
Discussion in 'Complete Vehicles' started by big pappa b, Sep 28, 2005.
  1. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I may have a local buyer for this but here it is anyway:
    1980 K5: It's a biglist but here goes. 454/NP205/SM465 - 205 is still slip yoke but I have the parts to make it a fixed yoke.
    Motor is a stock bore 454 with Comp cams 268H cam, powder coated Edelbrock RPM Air Gap intake, Edelbrock 750cfm carb, K&N 5" air filter, Hooker super comp ceremic coated headers, Centerforce clutch with approx 1000mi, Brand NEW Optima battery, NEW Beard Super Seats, Bestop Soft top in good shape, new 4 core radiator
    NEW JAZ 22gall fuel cell with foam in steel can mounted in bed
    Front Axles: - D60, ORD Crossover steering, bolt in brace, Missouri Offroad diff cover, 4:56 gears, also have but not installed--> NEW Detroit locker, NEW 35 spline outer shaft, u-joints and NEW MT. Logan drive flanges
    New hydro assist steering. Cylinder is a Chief 2x8 w/3000psi. Hoses are heavy duty 2 wire type lines. Steering box is an AGR box
    There is also an ORD bolt in steering box frame brace
    Rear axle: 14B FF, detroit locker, 4:56 gears, Missouri Offroad Diff cover, Missouri Offroad axle truss, disc brakes (no emergency brake)
    Tires and wheels are both NEW (1 run..about 2 trails worth)- 15x10 US Wheel 4" bs -
    Tires 39'5 x 13.5 x 15 IROKS biased ply
    extended stainless brake lines front and rear, new u-joints all the way around,
    Suspension: All NEW front 4" Tuff Country EZ rides w/ ORD greasable shackles
    Rear springs are NEW F*rd 57" leafs w/ Echobit shackle flip and ORD greasable bushings.
    There is also a new axle wrap bar built out of .219 wall tube that was installed just before it's only trail ride. NO axle wrap here :D
    Rear bumper is a 4x4 Iron with swing out tire carrier. Spare tire is a 38" TSL with not a lot of tread but a good trail spare
    Front bumper is a Smittybilt tube bumper
    Also has new custom made rock sliders made from 3x3 .120 wall tube with 1.75" .120 wall steps/trees guards
    Things I have but not installed:
    NEW Detroit locker, NEW 35 spline outer shaft, u-joints and NEW MT. Logan drive flanges, NEW IN BOX full set of front carpet (black), center console, almost new electric fan with shroud, NEW hood pin kit from PolyPerformance, NEW inside winch controller panel from Seabass.
    I also have the factory hard top that is camo and in good shape
    The K5 has been wheeled 1 time since all new parts were put on so there isn't much wear on anything. It has been parked since April after the trail ride.
    The exhaust is new also. Duals with bullet style turbo tubes (no cats) that turn down just before the axle
    Price is $6500...not negotiable so don't ask and I'm not parting it out at this time
    We are building a street car instead. Something we can enjoy any day of the week and not have to drive 3 hours each way to do it
    PM me or email to bigpappab@gmail.com
    Asheville, NC
    Pics are in my webshots link below
  2. bryanrash
    bryanrash Registered Member
    Dec 7, 2003
    38
    PM Sent
    I sent a PM
  3. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Sent PM about NEW IN BOX full set of front carpet (black)
  4. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    PM's sent
  5. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I'm getting closer to parting it out. There is the possibility that the 454 will be coming out for a little "makeover' before it goes into the Malibu...if I get it tomorrow. The local guy really only wants the axles a will pay good $$$$ for them. That leaves a lot to part out.
    Not going to ppost any prices on stuff yet but if there is anything you would be interested in just let me know
  6. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
  7. BlazaBlazeII
    BlazaBlazeII Registered Member
    Feb 1, 2005
    68
    Ann Arbor, MI
    Interested in Front and Rear Bumpers and Sliders.
  8. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I have 1 person that wants the front and 1 that wants the rear. Front person is local so that one has better chance of being sold. Will let you know about the rear as the buyer lives a few states away and shipping it could be an issue. The rock sliders are welded to the frame, not bolted on. I can either cut them off or you can come get the body :p:
  9. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Axles can be had for $2300 with the following:
    Front D60:4:56's – open, Missouri Offroad diff cover, 30 spline manual hubs
    Rear 14B:4:56's, Detroit locker, Disc brakes, Missouri Offroad Diff cover, Missouri Offroad Axle Truss
    Complere ORD Crossover steering - $275
    Complete Hydro assist setup. Only 1 run on it.
    3000psi hydro cylinder (2x8 stroke)
    2 - new 2 wire hydro lines
    AGR steering box with tapped top car and tapped EMS offroad billet end cap. Box is used but in great shape - $400 for all
    All you need is the mounting brackets for the cylinder
    D60 Detroit locker - New in box $450 - Pending
    2 – new in box Kingpin rebuild kits...Pending
    2 – new in box 35 spline outer shaft...$150..Pending
    2–New in box Mt. Logan 35 spline drive flanges-$125 Pending
    Besttop Soft top in good shape...$300..Pending
    Almost new set of Ford 57" rear leafs and Echobit shackle flip...$275 (1 trail run on setup..2 trails at Tellico, only mildly flexed
    4" Tuff Country EZ ride front leafs $150...same 1 trail run on them-Pending
    Front bumper is a Smittybilt tube bumper...$250..Pending
    4x4 Iron Rear bumper w/swing out tire carrier and shackle attachments $400..SOLD
    Front and rear stainless extended brake lines $50 for the set..Pending
    Pair front ford shock towers $20
    SM465 - 10 spline with shifter $100
    NP205 - 10 spline slip yoke rear with shifter - $150
    Package deal - SM465/adapter/NP205 $250 - Pending
    Fixed yoke conversion with new gasket - $100
    JAZ 22 gallon fuel cell with can..still on it's first tank of gas..fittings included $300
    Almost new 39.5"x 13x15" IROKS....Wheels are 15x10 w/2.5" BS.... the same 1 trail run..no cuts - wheels are painted OD green$800
    NEW dual exhaust system and matching camo hardtop are included
    Also has new custom anti wrap bar w/heim front and stainless shackles
    Rock sliders are 3x3 square tube welded to the body...THEY DONT MOVE!
    Truck can be had complete minus the motor for $5500
    Can possible meet with some items for gas money. Trying to sell locally before I post it elsewhere
    I will wait a few days hoping someone buys it complete before I start stripping it down
  10. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    I'll take those front springs if you part it Bryan.
  11. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    What's your timeframe for needing them? I will be traveling up I-81 to the Harrisburg, PA area around X-mas. If you had a reason to be over that way I could meet you and drop them off...if not
  12. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    No rush, if you could ship them that would be better, Harrisburg is 3 hours from me.
  13. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Updated availability
