I'm done too...1980 K5......SOLD!!!!!!
Discussion in 'Southeast Region' started by big pappa b, Sep 28, 2005.
  1. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I may have a local buyer for this but here it is anyway:
    1980 K5: It's a biglist but here goes. 454/NP205/SM465 - 205 is still slip yoke but I have the parts to make it a fixed yoke.
    Motor is a stock bore 454 with Comp cams 268H cam, powder coated Edelbrock RPM Air Gap intake, Edelbrock 750cfm carb, K&N 5" air filter, Hooker super comp ceremic coated headers, Centerforce clutch with approx 1000mi, Brand NEW Optima battery, NEW Beard Super Seats, Bestop Soft top in good shape, new 4 core radiator
    NEW JAZ 22gall fuel cell with foam in steel can mounted in bed
    Front Axles: - D60, ORD Crossover steering, bolt in brace, Missouri Offroad diff cover, 4:56 gears, also have but not installed--> NEW Detroit locker, NEW 35 spline outer shaft, u-joints and NEW MT. Logan drive flanges
    New hydro assist steering. Cylinder is a Chief 2x8 w/3000psi. Hoses are heavy duty 2 wire type lines. Steering box is an AGR box
    There is also an ORD bolt in steering box frame brace
    Rear axle: 14B FF, detroit locker, 4:56 gears, Missouri Offroad Diff cover, Missouri Offroad axle truss, disc brakes (no emergency brake)
    Tires and wheels are both NEW (1 run..about 2 trails worth)- 15x10 US Wheel 4" bs -
    Tires 39'5 x 13.5 x 15 IROKS biased ply
    extended stainless brake lines front and rear, new u-joints all the way around,
    Suspension: All NEW front 4" Tuff Country EZ rides w/ ORD greasable shackles
    Rear springs are NEW F*rd 57" leafs w/ Echobit shackle flip and ORD greasable bushings.
    There is also a new axle wrap bar built out of .219 wall tube that was installed just before it's only trail ride. NO axle wrap here
    Rear bumper is a 4x4 Iron with swing out tire carrier. Spare tire is a 38" TSL with not a lot of tread but a good trail spare
    Front bumper is a Smittybilt tube bumper
    Also has new custom made rock sliders made from 3x3 .120 wall tube with 1.75" .120 wall steps/trees guards
    The exhaust is new also. Duals with bullet style turbo tubes (no cats) that turn down just before the axle
    Things I have but not installed:
    NEW Detroit locker, NEW 35 spline outer shaft, u-joints and NEW MT. Logan drive flanges, NEW IN BOX full set of front carpet (black), center console, almost new electric fan with shroud, NEW hood pin kit from PolyPerformance, NEW inside winch controller panel from Seabass.
    I also have the factory hard top that is camo and in good shape
    The K5 has been wheeled 1 time since all new parts were put on so there isn't much wear on anything. It has been parked since April after the trail ride.
    Price is $6500...not negotiable so don't ask and I'm not parting it out at this time
    We are building a street car instead. Something we can enjoy any day of the week and not have to drive 3 hours each way to do it
    PM me or email to bigpappab@gmail.com
    Asheville, NC
    Pics are in my webshots link below
  2. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Axles can be had for $2300 with the following
    Front D60:4:56's – open, Missouri Offroad diff cover, 30 spline manual hubs
    Rear 14B:4:56's, Detroit locker, Disc brakes, Missouri Offroad Diff cover, Missouri Offroad Axle Truss
    Complere ORD Crossover steering - $275
    Complete Hydro assist setup. Only 1 run on it.
    3000psi hydro cylinder (2x8 stroke)
    2 - new 2 wire hydro lines
    AGR steering box with tapped top car and tapped EMS offroad billet end cap. Box is used but in great shape - $400 for all
    All you need is the mounting brackets for the cylinder
    D60 Detroit locker - New in box $450
    Besttop Soft top in good shape...$300
    Almost new set of Ford 57" rear leafs and Echobit shackle flip...$275 (1 trail run on setup..2 trails at Tellico, only mildly flexed
    4" Tuff Country EZ ride front leafs $150...same 1 trail run on them
    Front bumper is a Smittybilt tube bumper...$250
    4x4 Iron Rear bumper w/swing out tire carrier and shackle attachments $400
    Front and rear stainless extended brake lines $50 for the set
    Pair front ford shock towers $20
    SM465 - 10 spline with shifter $100
    NP205 - 10 spline slip yoke rear with shifter - $150
    Fixed yoke conversion with new gasket - $100
    JAZ 22 gallon fuel cell with can..still on it's first tank of gas..fittings included $300
    Almost new 39.5"x 13x15" IROKS....Wheels are 15x10 w/2.5" BS.... the same 1 trail run..no cuts - wheels are painted OD green$800
    NEW 2.5" dual exhaust system and matching camo hardtop are included
    Also has new custom anti wrap bar w/heim front and stainless shackles
    Rock sliders are 3x3 square tube welded to the body...THEY DONT MOVE!
    Truck can be had complete minus the motor for $5500
    Can possible meet with some items for gas money. Trying to sell locally before I post it elsewhere
    I will wait a few days hoping someone buys it complete before I start stripping it down
  3. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I believe the soft top, bolt in steering brace and king pins kits are spoken for..possible the front springs and shackles too
  4. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Besttop Soft top in good shape...$300..Pending
    Almost new set of Ford 57" rear leafs and Echobit shackle flip...$275 (1 trail run on setup..2 trails at Tellico, only mildly flexed - Pending
    4" Tuff Country EZ ride front leafs $150...same 1 trail run on them - Pending
    Front bumper is a Smittybilt tube bumper...$250..
    4x4 Iron Rear bumper w/swing out tire carrier and shackle attachments $400..Pending
    Front and rear stainless extended brake lines $50 for the set..Pending
    Package deal - SM465/adapter/NP205 $250 - Pending
    Fixed yoke conversion with new gasket - $100 - Pending
    NEW dual exhaust system and matching camo hardtop are included
    Can either cut them off the body or you can buy the body :D
  5. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Made a few changes on the axles and hydro assist stuff
  6. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    what included with this?
    ryan
  7. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Just like what you get from ORD...
    This includes the pitman arm, steering arm, draglink and end kit.
  8. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Will know tomorrow for sure but it looks like the K5 will be sold complete. I will have a few parts leftover that I will list then
