I'm getting high while driving, S%@*!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lsak5, Apr 4, 2002.
  1. lsak5
    lsak5 Registered Member
    Mar 19, 2002
    26
    Marietta, GA
    I\'m getting high while driving, S%@*!
    My Blazer puts out an awfull lot of exhaust fumes. With the rear window down and the top on, we get high on exhuast fumes. Even with the top off, it's still pretty bad. I'm not sure if the carb is that bad out of adjustment because it does it all the time and always has. I've got a new Jet Performance Q jet on the way and am hoping it well help. But I'm not real sure what the problem is.
    Luke
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    Re: I\'m getting high while driving, S%@*!
    reroute your exhaust to behind the rear wheels, not strait out the back or under the diff.
    ARQ.
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    roll your window up...
  4. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Even then (dual exhaust behind rear tires) .my exhaust comes in. The only solution has been to open atleast one of the side windows (drivers or passenger rolldown window).
    I even tried a down spout, if you will. Strange how the OEM single exhaust out behind the passenger rear tire did not do this with the back window rolled down.
    I think someone found the "funny wing" that blows the air from the top of the top and directs is to blow down the window solved this problem. Looks like @#it though.
    TO
