Im going to get a lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tecton, Mar 3, 2003.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    I think im going to do it
    86 k5
    i want a full kit with rear springs and shocks
    i have 33's and at the most ill get 35's but i want alot of room for travel without it looking like its got little feet.
    4 or 6 inch?
    and which brand....
    budget is about 500$ minus labor
    (btw, i know very little about this to feel free to reply in essays and such)
    will my stock axles handle a lift?
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    If you'll never get the really big tires, then go 4" with Shackle flip in rear, and trim the fenders. Axles survival really depends on what gears are in your stock axles. I really like the 3/4 ton axle swap becouse you'll get a very strong rear axle, and the lower gears that'll make the difference (As well as keep ya from burning up automadic transmissions) and beefer breaks. /forums/images/graemlins/thumb.gif
  3. tecton
    Dec 1, 2002
    1,553
    WV
    been lookin at that rear disc kit
  4. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I would say go and look at National Tire & Wheel they have a 2 or 4in lift with rear springs for 499.95 and it comes with shocks you will have to get the raised steering arm but over all I don't think it's to bad of a price.
    I did call them awhile back and was told the spring were Superlift superride springs if thats still true then you'll end up with a good ride.
    Eric
  5. tecton
    Dec 1, 2002
    1,553
    WV
    should i order it, have it sent here, then take it to a garage, or just have the garage do it all....or buy a keg and see how many neighbors show up to help?
  6. bigjbear
    Feb 18, 2000
    13,970
    451
    Marietta GA
    IIRC, you want a show truck not a wheeler. Correct me if I am thinking of the wrong person because it matters. These kind of"?" need a description of your plans/intended usage of the truck. If that is the case then a 4" lift w/ some well done fender trimming would do the job. Stock axels would be fine. Skyjacker, Tough Country, and BDS all seem to get consistantly good reviews on this page. Do a search if you haven't already, this (4" & 35s) is prob the most frequently asked question.
  7. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    $500 is a pretty tight budget for a full spring lift kit. You could possibly buy the Rough Country kit, but it's $499 without shipping, and shipping on a full spring kit is not cheap. My kit, with rear blocks plus the steering arm and braided brake lines cost me $509 from www.4wheelparts.com, and that was with free shipping. A 4", you will need to buy the driveshaft spacer for the front, your rear should be long enough. The spacer is about $50. I also had the saggy butt syndrome these trucks get, so I had to buy an add-a-leaf for it, which was another $60. Total, I spent $619 on my 4" kit. It's a little taller than 4", I got 5.25" out of it. You can do these things cheap, but you don't want to. Don't go cheap with the suspension, just like you don't go cheap on brakes. Wait for a bit longer for some extra cash and do it right the first time.
    If you have a 4-wheel parts near you, go in and get their Genuine Suspension kit. It has the 4 springs (Pro-comp springs), brake line extensions (not braided steel lines), front/rear u-bolts, and shocks for $496.99, but that's without tax ans the steering arm. Steering arm is $57.99, plus those springs will make you ride like a tank. Like I say, save some more cash, and search on the board for good lift kit recommendations. They're all over the place. Sorry for the novel!
  8. bad andy
    bad andy 1/2 ton status
    Mar 5, 2003
    151
    Charlotte, N.C.
    i like the keg idea /forums/images/graemlins/eek.gif
  9. tecton
    Dec 1, 2002
    1,553
    WV
    i live in southern wv
    show truck, means u wash it after u go wheeling, lol
    no ive tried to hold out...keep it clean, dont go up that hill...la la la...but i just cant, especially with summer coming...so i want it as strong as i can get it...its my DD also...well...ONLY Driver i should say
  10. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Rough Country rides like it's name ROUGH !!! Tough Country has a much better ride. Very importent for a DD in my opinion.
  11. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    i have researched this quite a bit with the folks on here, and this is what i hear, and will be doin when i get un-broke, ORD 4" shackle flip in the rear, then buy their 2" rear springs to get a total of 6", then get the 6" tuff country lift that they sell there www.offroaddesign.com is the place, but i still will have to buy the steering arm extender thingy, maybe driveshafts for 6", and brake lines, an i think thaz it, but its supposed to be very good, reliable, flexy, ride good, and to my surprise, kinda cheap, but will cost you more than 500 if you go 6", maybe around there for the 4", hope this helps, do some more research, and let us know what you choose...
