I'm gonna make a ramp... one of those rti ones...
Discussion in 'The Garage' started by reddog64, Dec 12, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I\'m gonna make a ramp... one of those rti ones...
    At least I think it is rti...
    What angle do I make it at and how long should it be.. final height....
    Anyone have any measurements? /forums/images/graemlins/confused.gif /forums/images/graemlins/k5.gif
  2. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    Re: I\'m gonna make a ramp... one of those rti ones...
    Generally they are 23 degree. But you could probably get away with a 30 degree because your flexy. Just remember to double check your measurements. I thought i was making a 30 degree and it ended up being 37 or something. The way to do it is first figure out what degree you want it to be. Then you can either work on the hieght or the length of it.
    length use cos(angle) / (length) = (inline legth)
    height use sin(angle) / (height) = (incline length)
    Then use pothagoriums theorum a^2 + b^2 = c^2; where c is the hypotunuse(inclune length).
    NOTE: take into the effect the size of the metal used and measure from either the inside or the outside or the tubing and be consistant with it (what i f***ed up on)
    Ok got to thinking again and you can base it off of a 3 - 4 - 5 right triangle. It would be a 30, 60 , 90 degree. But double the lengths. So your sides would be 6' x 8' x 10'. That should give you more than enough room.
  3. reddog64
    Nov 9, 2000
    3,325
    Thanks Bud!
    I printed it out! LOL
    /forums/images/graemlins/thumb.gif
  4. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    Good luck with the ramp. Show us pics when you get it done.
    Will
  5. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Aaron, Better Off Road in Oak Harbor has one. The dude that owns the place is cool. Maybe come over and make a sketch of it, dimensions and stuff. Later Jeff
  6. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    I made mine 20 degrees and 12' long. I can max that so I am going to make it adjustable from 25-30 degrees. If I had it to do over again I would just make it 30 degrees.
