I'm in over my head, 35-spline hub Q?
Discussion in 'The Garage' started by eldon519, Jul 18, 2003.
  1. eldon519
    eldon519 1/2 ton status
    May 27, 2002
    161
    Kennesaw, Georgia
    I\'m in over my head, 35-spline hub Q?
    I've been doing some searching and reading some threads about problems with the Warn 35-spline hubs hitting the end of the stub shaft. I've got the same problem so apparently I need a new bearing race(part 382S?). Can someone tell me what company makes 382S and where I could buy them from? Also what all is involved in the replacement? Finally, are they expensive? Sorry to ask so many questions but I gotta get this fixed before something nasty finds its way into my axle. Thanks ahead of time /forums/images/graemlins/confused.gif
  2. eldon519
    May 27, 2002
    161
    Kennesaw, Georgia
    Re: I\'m in over my head, 35-spline hub Q?
    Anybody? Please? /forums/images/graemlins/crazy.gif
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    no idea. you've called all the parts houses, i assume (Randy's etc.)
  4. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    That part number is is all you need, go to any good parts house and they should be able to use it. Find someone that stocks BCA or Timken brand bearings and give them the number. /forums/images/graemlins/deal.gif
    Sorry, I don't have any idea on the price. Also, some races are only sold with the bearing so you may have to buy more than you want to get what you need.
  5. eldon519
    May 27, 2002
    161
    Kennesaw, Georgia
    Thanks for the advice fellas. That should help me get her rolling again /forums/images/graemlins/thumb.gif
  6. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    Talk to "Keith" he had the same prob and is right up the road from you.
  7. Shagnaz
    Shagnaz 1/2 ton status
    Jul 19, 2002
    308
    South Carolina, North Charleston
    That part # is the inner bearing of the hub. And, it is
    a Timken part #.
    The Warn hubs for the 35 spline are not the greatest.
    Tera Flex has a set out and are warrantied
    The bearing is @ $12 and the race is seperate unlike the
    outter bearing that comes as a set.
    You can get Timken from Autozone.
    Mike
  8. eldon519
    May 27, 2002
    161
    Kennesaw, Georgia
    Yeah, I knew the Warn 35 spline hubs aren't too great so I actually went with the Milemarker units. I was also sold on the fact that they have a spring loaded mechanism which allegedly ends the need to have to move the truck back and forth to get them to lock. Unfortunately they haven't installed as planned either. If I can't get these to work, maybe i'll go with the Tera Flex units. Anyway, thanks for the advice again, this is incredibly helpful. /forums/images/graemlins/laugh.gif
  9. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    The Tera-Flex hubs are relabeled MM's, so if your MM's don't work you will not like the TF either.
  10. eldon519
    May 27, 2002
    161
    Kennesaw, Georgia
    Well the MMs fit on one side but not on the other. Maybe I'll try swapping them side to side to see how it works. I've heard that can help on the Warns in some situations.
  11. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    That race you refer to is the carrier bearing race for the Dana 60. /forums/images/graemlins/grin.gif I ground my end stubs pretty good and have had no more trouble.
