Im installing my Extended brake lines and have a question?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76_Cheyenne, Jul 5, 2002.
  1. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    On the front lines, when you bolt the new ones back up to the caliper does the bolt with the hole in it have to line up exactly to the hole on the line?
  2. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    Nope.
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Nope....fluid flows into a small chamber in the block at the end of the line, then into the holes in the banjo bolt, then into the caliper.
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Nope. You can turn the banjo bolt wherever you want to get the best clearance so that the brakeline clears and does not hit anything in the path of the turning radius. /forums/images/icons/wink.gif
