I'm jealous!
Discussion in 'The Lounge' started by dontoe, Jun 22, 2006.
  1. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
  2. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Jealousy doesn't begin to describe my feelings. I need to win the Lotto......
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Exactly.
  4. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    I want one, no make it two, no three, and a spare one............
  5. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,812
    396
    Clayton Del
    Whats that thing on the back corner? some type of dish?
  6. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Satellite transceiver I expect..................it has the works! :eek1:
    Ya know, so you could hang in the lounge, while in the middle of the Moab!
  7. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    M'kay, so how come this does not sound right.
  8. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Maybe it sticks a potato onto your tailpipe to slow ya down...........:p:
  9. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    that thing is awesome, its got more radio than my alpha command COC truck had.
    And this
    Rocks
  10. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    Wow, talking about a 700lb gorilla. 13,000 + lbs. but still bad ass.
  11. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    18.6. RESCUE and RECOVERY EQUIPMENT
    • 18.6.1. Spare Tire holder bracket and winch based raise/lower system.
    • 18.6.2. Two high capacity earth anchors
    • 18.6.3. 200’ of stainless tow cable
    • 18.6.4. Transfer pulleys
    • 18.6.5. Tree savers and padding
    • 18.6.6. Nylon tow straps
    • 18.6.7. Assorted shackles and couplings
    • 18.6.8. Two 5 ton Come-alongs w 30’ cable
    • 18.6.9. Sand ladders
    • 18.6.10. Two combination shovel/axe/picks
    • 18.6.11. High Lift jack
    18.7. TOOLS
    • 18.7.1. Hand Tools (US and Metric)
    • 18.7.2. Power tools
      • 18.7.2.1. Electric
        • 18.7.2.1.1. 3/4” right angle drill
        • 18.7.2.1.2. Sawzall
        • 18.7.2.1.3. Arc welder
        • 18.7.2.1.4. Disc Grinder
      • 18.7.2.2. Pneumatic
        • 18.7.2.2.1. Air die grinder
        • 18.7.2.2.2. Air compact wrench
      • 18.7.2.3. Hydraulic
        • 18.7.2.3.1. Waterproof Chain saw
        • 18.7.2.3.2. 3/4” Impact Wrench
        • 18.7.2.3.3. Cable and bolt cutter
        • 18.7.2.3.4. Rescue/recovery tool
    • 18.7.3. Special Maximog specific tools – Various adapters, jigs, gear pullers. Etc
  12. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    My only negative observation was the size of the engine for that big a rig and trailer. I'd have been inclined to go big diesel or at least bigger on the gas engine.
