Im Joining The Big Boys!!!
Discussion in 'The Garage' started by George_Pimpdaddy, Apr 5, 2007.
  1. George_Pimpdaddy
    George_Pimpdaddy 1/2 ton status
    Oct 17, 2002
    1,306
    Edmonton Alberta Canada
    So this weekend is the install of my 3/4t 10bolt and a 14bolt FF both wiht 4.10:eek1:
    Just gonna have to source out a pair of rims 15" 8 lugs.
    So that being said any tips tricks or hints from the brotherhood?
    I know its been posted but off hand anyone know the napa part number for the conversion u joint?
    Also can i put my alburn posi in my new front axle from my old rear?
    Thanks guys:bow:
    89:k5: 10bolts posi in rear
    355/700r4/241
    35" BFG Mud Terrains
  2. 01maroonz71
    01maroonz71 1/2 ton status
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    your in the same boat as me....except i got the hubs/backing plates for the front instead of a whole new axle....good luck man
  3. RIPPEDK5
    RIPPEDK5 Guest
    your 15" rims probably wont fit. unless you are going grind down the calipers which i wouldnt recomend.. Why dont you scavange a junk yard for a 3/4 driveshaft with a slipyoke (assuming you have a slip yoke transfercase) ...For the coversion u-joint..ask them they will have it--i had one but its gone i guess now.
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    there is nothing wrong with grinding the calipers, you dont grind down anything that is structural. i duno how ur parts store is, but mine is retarded and doesnt know what a coversion ujoint is, ull need the part number. why go find a 3/4ton drive shaft? thats alot more work, because youll have to get it shortened since its a k5, alot more money, stick with the conversion ujoint for $25
  5. greywolf
    greywolf 1/2 ton status
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    there are 15" rims on my 3/4ton and they dont look shaved.
  6. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    it also depends on how much backspacing you've got. if you didnt need to shave any then you got lucky:D
  7. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    yeah, but some like em shaved...:wink1:
    does anybody know what backspacing will keep me from having to shave my calipers???? i'd love to keep my 15in wheels/tires since i've basically got brand new tires. THANKS!!!
  8. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    2.5"-3" and u should be fine. it will hurt your turning radius tho.
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Congrats on the new stuff :waytogo:
    But , to really be a big boy , you need a D60 , some really large tires , doubler , multiple sticks , tube , a diesel truck , and trailer :wink1:
  10. mrdrinksalil
    mrdrinksalil 1/2 ton status
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    yeah, the "Big Boys" have 60's up front brotha! Congrats on the upgrade though
  11. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    I've got like 4" of bs and had to grind a TON :) But its do-able.
    Like the others said I believe 2.5" is safe for not having to grind much if any at all...
    Oh and my local NAPA was stupid...they said it was discontinued so I just ordered it off of their website :) Its NAPA #447
  12. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    or with a racing stripe.
    btw, i'll have to steal that quote, thank you.
    constantly wondering what you'll break next is half the fun. you'll just have to do crazier stuff now so you can still tell stories of fun trail-fixes.
  13. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
  14. George_Pimpdaddy
    Oct 17, 2002
    1,306
    thanks for all the input guys just have a few more questions to clear up
    1. what backspacing should i look for? im not to crazy about grinding but do understand the process.
    2. should i put a zero rate block on the rear axle to temporairly fix my saggy but? im sure i could still use the factory shocks right?
    (just till i save up a little more for the right lift im leaning towards BDS 4" Suspension)
  15. stoney126
    stoney126 1/2 ton status
    Jun 2, 2005
    1,458
    napa,CA
    what is the conversion u joint for ? Im doing the same thing you are, I dont want to be surprised:D
  16. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    sorry to hijack, but is it the same for the front? Im going 8lug 10 bolt up front with a 14ff in back.
  17. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    yeah 10b and d44 are the same 1/2 ton u-joint...
  18. Bow-Tie-Boy
    Bow-Tie-Boy Registered Member
    Feb 14, 2005
    71
    Ft. Hood, Texas
    The D60 will have a 1310 yoke on it as well unless someone has already changed it over. I was once told that GM used the 1310 yoke on all of their front ends.....so far I have found this true
