I'm lazy!!!! what kind of gun do I need to spray on bedliner?
Discussion in 'The Garage' started by jjlaughner, Nov 19, 2003.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I\'m lazy!!!! what kind of gun do I need to spray on bedliner?
    Just like it says, I want to spray on my duplicolor bed liner. Can I use a regular paint gun or does it need rejetted/nozzle or is there a special bedliner gun? There are a couple on ebay I'm looking at. /forums/images/graemlins/1zhelp.gif
  2. Nike
    Nike Registered Member
    93
    Jefferson City, Missouri
    Re: I\'m lazy!!!! what kind of gun do I need to spray on bedliner?
    One of the bedliner companies sells one for $35.00, and I think it is Duplicolor. O'Rielly Automotive has them. You need a siphon feed gun with a 1/4 inch tip.
  3. earl87gta
    earl87gta 1/2 ton status
    Apr 6, 2003
    551
    Chuckey TN
    They use some kind of a presure pot or somthing my budy calls it it does have a bigger nosl then a standard paint gun.
  4. Wally81k5
    Wally81k5 1/2 ton status
    Jul 14, 2002
    139
    Cold Lake Alberta
    it called a shautz (sp?) gun, just a normal spray gun, but with a huge tip. Make sure you get the right one, i did a bedliner before and due to the hole being to small i had to thin it out, and it just turned thin and britle, it was epoxy base (brittle) go with something that is polyurethane.
  5. earl87gta
    Apr 6, 2003
    551
    Chuckey TN
    I think the gig tip is used becouse some of the liners like herculiner have ruber chips in them you can buy a kit from thir site with a gun.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Be sure to read all the fine print first, to find out what type of respirator you will need to use. I'm sure that breathing in bedliner mist is NOT good for you. /forums/images/graemlins/eek.gif
  7. Grim-Reaper
    7,385
    Atlanta
    It's called a undercoating gun. I'm going to shoot hurculiner. This gun will pass huge solids no problem.
    The Duplicolor is junk. It's thick paint.
  8. thefarside
    thefarside 1/2 ton status
    Jun 27, 2003
    343
    Vernon, CT
    How does Hurculiner hold up? As good as Rhinoliner? Is there a difference between the two, other than a price gap?
    I ask because I plan on using some form of spray-on bed liner to the bed and under my truck.
  9. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    rhino is thicker, sound deadens better, and is generally tougher. All of that said, I luv my herculiner. /forums/images/graemlins/grin.gif its cheap, seems to hold off rust, is purdy tough if u prep right, and you can say "I did that myself". /forums/images/graemlins/laugh.gif
    j
