Im lifted
Discussion in 'The Garage' started by Scuba Steve, Dec 6, 2003.
  1. Scuba Steve
    Scuba Steve Registered Member
    Jul 17, 2002
    99
    Fort Bragg, NC
    Just got done putting a 4inch TC lift on with ORD HD shackles and swaybar disconnect. But I could not get the steering arm off to put on the new one. Anyone have any tips? /forums/images/graemlins/thinking.gif
  2. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    Sorry, no tips, but I sure would like to see some pics!
    -Andrew /forums/images/graemlins/usaflag.gif
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Just keep hitting the arm with a good 3 pound hammer/sledge. Don't go easy on it. Eventually you'll get the cones to pop loose and you can get the arm off then. Penetrating liquid on the studs/cones will help too. Just keep working on it. It has to come off at some point (I've done 2 already, and they've both been beasts!)
    Post some pics of your truck with its new stance. /forums/images/graemlins/thumb.gif
  4. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    Take everything off of the knuckle, including the backing plate. And hit it all the way around. (spent 2 hours trying to take it off and my dad got it in 15 after he took the stuff off.)
  5. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Just keep pounding on it right where it curves back, eventually the cones will loosen and pop up. I have taken 3 off this way.
  6. Get a brass drift and after shooting some PB Blaster on the the cones, hit right next to the cones all the way around them with the drift. It works every time. By using the brass drift, you wont damage your threads if you hit them. I learned this by taking the manual hubs off my old 4Runner. It said to do it right in the factory service manual from Toyota, so I tried the same trick with those cone washers and it works. Or you could just beat the hell out of it with the sledge /forums/images/graemlins/laugh.gif
    Mat
  7. vince13
    vince13 1/2 ton status
    Dec 6, 2001
    105
    Penticton, BC Canada
    you can also try heating it up, not too hot, but just enought to loosen it off, i used a blow torch and let it sit there for 15 minutes and one tap with a hammer and it popped right off.
  8. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    I just got a surplus of diff and had to knock of a few of the steering arms. I did the one on the truck, I didn't need to take anything off as far as backing plates and stuff, I just moved my brake line out of the way and started smacking.
    I searched on here and people said to hit it where the draglink connects, I found it best to hit right up close near the bolts, leave the nuts on a few turns just so you don't accidentily smack the threads. I found that it took no more than 3 hits to get the wedge lock things to pop out a bit then I just un threaded them by hand, sometimes it might take a little punch to get them to start unthreading. Thrust me this way works. Another tip, if your changing over diffs such as I was don't smack your steering arm too hard, I noticed mine had a hairline crack in it and junked it, doesn't matter much with the stock one though. Like others said spray the bolts with some good quality penetrant, I used Wurth Roost off, best stuff ever. You don't need alot just enough to get down inside there.
  9. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    took me 4 hours to get mine off /forums/images/graemlins/angryfire.gif yup big sledge hammer is the only thing that worked.
  10. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    On the top of the steering arm, back where the arm attaches to the draglink, theres a set of numbers casted into the arm. Use a 3# sledge and give it a couple whacks right on those numbers. I found that tip on this site. I tried it, 2 hits the cones were out /forums/images/graemlins/thumb.gif
  11. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    Hey Steve when I come over we will try to get it off again ok. /forums/images/graemlins/thumb.gif Find a realy big hammer ok.
  12. Scuba Steve
    Jul 17, 2002
    99
    Fort Bragg, NC
    cool thanks everyone for the tips.
  13. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    Yup...all of the above, main thing is having a BFH /forums/images/graemlins/grin.gif
    I had to grind some on my new arm to get it to go all the way down, so you may have to as well...maybe /forums/images/graemlins/thinking.gif
    Dont forget to snap some pics too /forums/images/graemlins/deal.gif
  14. 88Silverado
    Mar 13, 2003
    2,664
    Mee too. I had to slightly enlarge the holes and grind the arm to fit around the balljoint
  15. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    I soaked my with PB Blaster, and hit on this set of numbers with a sledge hammer, and it DOES work!! Good luck!
