I'm Not Drunk!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hayduke, Aug 28, 2001.
  1. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
    I\'m Not Drunk!
    hey there all,
    i've got a weird steering problem, sometimes (becoming more common) when i make a turn either way it seems to stick to that side, then because i have to correct the sticking i'm turning the wheel farther to the other side, sometime it just holds there pulling hard to that side until i turn the other direction. but at times while i'm holding the wheel to correct it just pops back and b/c i was holding the wheel to the other side i start to look like a drunk wobbling in the lane!.....fluid is fine, all lubed up, any help?
    Insured By COLT, Policy #.357M
    <a target="_blank" href=http://haydukesk5.coloradok5.com>http://haydukesk5.coloradok5.com</a>
  2. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    Re: I\'m Not Drunk!
    check your steering stabilizer, if its bent the piston can get stuck by the dent. Had this happen in CO. on a rock. Also make sure that your powersteering pump is good and belt is tight.
    Chris
    MY DRINKING TEAM HAS A FOUR WHEELING PROBLEM![​IMG]
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Re: I\'m Not Drunk!
    If you feel a lumpieness in the steering wheel it might me from the gear lash in the steering box being too tight (the adjuster on top of the box).
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  4. kumma
    kumma 1/2 ton status
    Oct 29, 2000
    380
    Novi, Michigan
    Re: I\'m Not Drunk!
    Sounds familiar, my jimmy does the same thing. I havent found the culprit yet but what i did do was to lock the hubs when im driving. the truck tracks straight as an arrow now and it doesnt wander. of course i drive in 2 hi on the street. i dont have a steering stabilizer either. I've replaced the drag link assembly and will do the tie rod ends and ball joints. I also have a spare steering box in case thats the problem. good luck.
    Craig
    "Why is there a <font color=red>watermelon</font color=red> here?"
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Re: I\'m Not Drunk!
    HAYDUKE!!!!!! CHECK YOUR STEERING BOX NOW! Mine did that and it was the steering box hanging onto the frame by two loose bolts. The other two were completely gone!
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  6. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Re: I\'m Not Drunk!
    I had this problem and it turned out to be the steering box.It seemed to have some sort of internal leakage issues.I instaled a new box to fix it.
    A balanced diet is a beer in both hands.<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  7. Hayduke
    May 9, 2000
    271
    NE Columbus, Ohio
    Re: I\'m Not Drunk! (Update)
    ok, i checked the box and it's on there tight, no leaks either, stablizer is fine. i tried locking the front (i have warn prems.) and that did the trick, drove straight as an arrow and the steering was way tighter than it's ever been, what are the downfalls to driving on the road in 2hi w/ the front hubs locked?
    but here's the kicker, i unlocked both hubs after driving with them locked for two days and the steering problem is GONE! no probs whatsoever for three days now, yet another GM gremlin?
    thanks!
    peace.
    HAYDUKE
  8. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    Hey, if its fixed, its fixed.
    35" All-Terrains... I don't get it.
  9. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    That is one of the wierdest things I've ever heard of.
    Maybe you're just getting older, and your tolerance isn't as high as it used to be? LOL
    Lift It, Lock It, LIVE IT!!!
  10. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    Just an idea... one of your hubs was stuck engaged before but you diden't know it. After you drove it around alitle and turned them off they both came disengaged like they where suposed to. Maybe just a question of cleaning/greasing upp the manual hubs again?
    <font color=red><a target="_blank" href=http://www.espen88k5.alloffroad.com>www.espen88k5.alloffroad.com</a></font color=red>
  11. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    may have needed to lube your wheel bearings a bit better. and that will do it.
    for those of you who dont know you should be driving for a day with your hubs locked. to lube everything up. and also for a short bit once a month in 4wd to lube even more up.
    Grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  12. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    You just need to go wheeling at least once a month. I go twice a week. Everything stays nice and lubed that way.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
