i'm retarded help me
Discussion in 'The Garage' started by muddysub, Dec 30, 2002.
  1. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    i\'m retarded help me
    i can't get the drums off my new (to me)14bff i removed the axle shafts and got to tuggin on the drums and they don't move.
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Re: i\'m retarded help me
    Rusted on..... /forums/images/graemlins/smirk.gif
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Errrr, unless you have one of the later 14 bolts, the drum is pressed onto the back of the hub, you need to pull the whole hub off the axle in order to get the drum off. </font color>
  4. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    hehe yeap...same with the drum on my rear 10 bolt...me and my dad tryed to check the brakes on it..could not get the drum of..even used a torch..we gave up and threw the wheel back on..the front two were good..and the rear driver side were fine..so we didnt bother with it/.. /forums/images/graemlins/tongue.gif
  5. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I like it when people admit there dumb...
    did ya pull the axles... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  6. muddysub
    Jun 23, 2001
    10,452
    489
    are they rusted on if they spin really easy?
  7. chevyfumes
    Feb 24, 2000
    38,584
    266
    Well you mentioned retarded , so I showed up with an opinion.... /forums/images/graemlins/1zhelp.gif
  8. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    you have to remove the hub. then press out the studs. to remove the drum. to do the brakes you can leave the hub on and have them turned that way, and do yer business then replace them.
    Grant
  9. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    beat on it /forums/images/graemlins/rotfl.gif, mine were rusted on my 10 bolt, before it blew up, but i just beat on them and eventually they came off with alot of beating and penetrant lube, that was a good combo. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  10. muddysub
    Jun 23, 2001
    10,452
    489
    10 and 14s are a world of difference. 10 are semi floating and my 14 is a full floater.
  11. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i couldnt get mine of even with a torch!!?? lol..
  12. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You have to first remove the outer wheel bearing, then the entire hub and drum assembly will slide off the spindle easily. /forums/images/graemlins/shocked.gif Welcome to the world of full floaters! /forums/images/graemlins/thumb.gif
    Oh yeah, be careful that you don't drop it on your toes as it slides off. Those things are HEAVY! /forums/images/graemlins/wink.gif
  13. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> You'd have to beat on a 14b drum for a long time with a REALLY big hammer in order to get it off without pulling the whole hub/drum assembly off. /forums/images/graemlins/eek.gif </font color>
  14. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    or just push it off the hub and let it ride on the axle housing, it will act like one of those bell things on the trash trucks when they back up.... /forums/images/graemlins/rotfl.gif
  15. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I think you'd still need the big hammer to squeeze the drum over the backing plate. /forums/images/graemlins/eek.gif </font color>
  16. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    Did you take off the two nuts? You need that six pin socket dealy, like the ones on the front spindle. Like they said, the whole hub has to come off. Or you could just give it too me cause your just too frustrated to look at it anymore. /forums/images/graemlins/grin.gif
  17. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    I love how people are telling you to remove the axle shafts when you allready said you did, asses, listen, if you allready got the 2 spindle nuts inside then just use a screwdriver to UNADJUST them smaller and itll let loose, and ignore my fellow HACKERS above /forums/images/graemlins/thumb.gif it is just because you have a tiny lip in the way from wear,
    and if all else fails, in the back of the backing plate, cut / grind off the ears that hold the shoe pins to the backing plate, itll all come off easy then.
    /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/thumb.gif
  18. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Wha? Hackers? I think people were telling him to remove the hubs, not the shafts. /forums/images/graemlins/rolleyes.gif </font color>
  19. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    I /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.giff the lock nut and ring clip thingy are off it should come off but that would be too easy. so get a BFH and a beer or mountan dew and start whacking.
    Btw, mine took about 6 hrs but it even spin good luck
  20. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I had the same problem when I tried to remove my 14 bolt's drums so I could put disc brakes on.
    One drum came off easily. The other was frozen on there.
    I ended up getting very frustrated and hooking a chain up on one side to the drum and on the other side to my other truck /forums/images/graemlins/ooo.gif
    Really, I'm not kidding, I did that and even then it still took some decent gas pedal to pull the damn thing off. Not surpisingly, I managed to mangle some of the innards of the drum brake setup (it turns out the wheel cyclinder was frozen solid pressing the shoes against the drum face w/ pressure.) That didn't matter to me since I had the discs to put on anyway.
    -- Mike
