I'm running the 12 1/4" travel Gabriel shocks with my stock mounts!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Emmettology 101, Jul 29, 2002.
  1. Emmettology 101
    May 9, 2000
    8,126
    FL
    I\'m running the 12 1/4\" travel Gabriel shocks with my stock mounts!
    I said what they hay this weekend and put them on with the stock mounts. I ran a rock crawl this weekend without problems!
    HAs anyone else tried this?
    I was goign to try and get a small rubber washer to fit on the sohck rod to watch travel but I didn't have time.
    So far, no problems!
  2. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Re: I\'m running the 12 1/4\" travel Gabriel shocks with my stock mounts!
    How is the ride with those? Are they softer than a RS5000?
    rene
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    It's been quite a few years since I had 5000's, but they do ride nice! These are a valve sensing shock. One thing I noticed right off the bat about them is that they push open. The Superlift and Explorer 3000's I had on it before wouldstay wherever you pushed them into but resisted pulling apart. These resist being compressed and once compressed they would psh out to full extension(slowly)..
    The ride is nice!
  4. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I believe that's because they are nitrogen charged, right?
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    They are what Gab calLs a VST(Velocity Sensitive Technology ) shock. And as I look through their site, they are a Nitro charged shock.. However when you shake them, I can hear a liquid in them..
  6. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Instead of hunting a rubber washer just use a zip tie.
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    Ya, forgot about that trick. I looked the shocks over and didn't notice any leakage or damage so all is well! /forums/images/icons/smile.gif
  8. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    part numbers pleasE ?
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    You can get them at Auto Zone, they are Gabriel part number G63438
    The application according to Gabriels site is a 73-8? Blazer(and other chevys) with a 4" lift!
  10. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    All gas charged shocks push themselves open. The liquid is the hydraulic fluid that shocks use to work. The damping comes from the fluid being forced through a valve. The gas charge is in another section and is used to keep the shocks cool.
  11. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the nitrogen keeps the fluid from foaming
  12. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Its nice someone else talking good about Gabriel shocks besides me. I switched from Ranchos to Gabriel LT shocks with the VST valving 2 years ago. Still no problems. I think they are a lot better shock then the rancho 5000s.They are quite a bit cheaper too. They Improved the ride and made my truck handle a lot better off road and on the pavement. They seem to react to changing conditions faster and better than Ranchos.
  13. Emmettology 101
    May 9, 2000
    8,126
    FL
    Someone else posted the number here and I just went out and bought them. They seem nice so far... /forums/images/icons/smile.gif And at $19.99 ea. you cant beat'em!
  14. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    $20 /forums/images/icons/shocked.gif . I wonder if these will work with a 2.5" lift?
  15. Emmettology 101
    May 9, 2000
    8,126
    FL
    THey will if you make new front and rear mounts.... I bet they would have a slightly shorter shock with a similar price..
  16. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    I will have to go check that out. I presently have procomp3000 all the way around. Good on the back becuase they are saggy old springs. The front is WAY TOO Stiff. I catch air hitting some expansion joints around here at 65 (we don't have the best roads /forums/images/icons/tongue.gif )
  17. Emmettology 101
    May 9, 2000
    8,126
    FL
    I checked Gab's site and all they list are stock shocks and 4" lift shocks. The G63438 are the rear shock. THey do list a G63437 which is a front shock for a K5 with a 4" lift. But they dont list dimensions. Usually the front shocks are a few inches shorter, so this may work good for you all the way around on a 2.5" lift for articualtion...
  18. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    Yea I don't want to go any softer on the rear 'cause it allready feels like it's close to bottoming out like it is now. Would I have to put extended mouts or do you think it would work ok for the front for a dd?
  19. BJarvis354
    BJarvis354 Registered Member
    Jun 17, 2002
    58
    New York City
    Which Gabriel shocks do you have the Red Ryders or the Sport Ryders? From the price I assume the Sports, since the Reds are cheaper and look smaller...Could be the VST LT shocks, but those are $39.99 /forums/images/icons/shocked.gif
  20. Grim-Reaper
    7,385
    Atlanta
    I been running these shocks for 4-5 years.
    Find some place you can get the truck flexed up all the way. Take the sway loose and the shocks that are on it loose. Once flexed measre the compressed and extend lengths. Take those mesurments to the Zone. They should have a chart with all the Gabrials specs. take an inch off the compressed lenghts. This is so you don't ever bottom out the shocks. If they bottom then it could break the shock mounts off. Bottoming out is supose to be handled by the bump stops.
    Find the shocks that match the travel the closest. That will give you the most travel possible. I need to go buy a new set for Dollar. The rear has come up three inches and the front one so I need a little more shock now. Everybody is so hip on relocating the rear shocks. I never had a problem with the shocks being my limiting factor on the rear. My parking brake cables are my problem. The retainer clibs have long since broken and when I get max flex the cable case pulls out of the bracket and sttarts applying the parking brakes. /forums/images/icons/grin.gif
    Yeah the front is a different story. My shocks do limit my down travel.
