I'm so stupid it hurts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLZN4FN, Feb 21, 2003.
  1. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    I\'m so stupid it hurts
    Ok im putting the rear 2.5 superlift rear springs in the K5
    and I looked down and the degree shim is facing the wrong way there is a sticker on the spring that says ft end. How do I tell ft from rear on the spring? I was thinking the just put the shim in the wrong way but would like to know which end is which before I put the heavy ass 14 bolt under there.
    Thanks,
    Bo
  2. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    Re: I\'m so stupid it hurts
    Admitting it is the first and most difficult step. /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
  3. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    measure from the front eye to the center pin and compare the number with the stock spring.if the center pin is dead center and the spring eyes are the same on both ends,it wouldnt matter.
  4. the professor
    the professor 1/2 ton status
    Feb 6, 2003
    130
    The thicker part goes to the rear..
    THe idea is to rotate the pinion up, to improve the dirve line angle /forums/images/graemlins/cool.gif /forums/images/graemlins/truck.gif
  5. BLZN4FN
    Dec 19, 2000
    1,720
    Englewood Colorado
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  6. BLZN4FN
    Dec 19, 2000
    1,720
    Englewood Colorado
    The thicker part of what part??
  7. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    he means the thicker part of the degree shim,but i dont thing thats what you were asking.just measure to the center pin from the spring eyes.if they put the shim on backwards,clamp the leaves together in front and behind the shim,loosen the center pin,spin the shim around and tighten it back up.
