I'M STRANDED>>>NEED HELP!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wsudu, Jun 10, 2001.
  1. wsudu
    wsudu Registered Member
    Jun 30, 2000
    43
    Wichita, Kansas
    I\'M STRANDED>>>NEED HELP!!
    My U-Joint broke last night on the 83'...The one where the rear shaft meets the transfer case yoke, not the differential. So I took, it out. Here's the problem.....These are the U-joints where the clips are on the inside, the half circles. Anyway, where the yoke and driveshaft meet, there are no bolts....It's all solid on all four of the ends...You have to pound all four of the caps out. So I do this and all but one cap will not come out...The wierd thing is that is moves up and down and side to side a little, but won't come out either way. I've done many joints before but this is crazy...I know this is a factory Spicer cap....Are they twisted in or something??? They clips came out, so it should too...It's going to be towed soon...Help me..thanks
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Re: I\'M STRANDED>>>NEED HELP!!
    It's probably been epoxied in at the factory. Try taking to it with the torch and knocking it out.
    I'm so poor I can't even pay attention [​IMG]
    <A target="_blank" HREF=http://pugsley.coloradok5.com>http://pugsley.coloradok5.com</A>
  3. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Torch. Be careful...when them caps get hot they fly. I recently saw one fly....right at my face and I was a good 10+ ft away.
    SK-15
    J**P...it's whats for dinner!
    Roads? Where we're going, we don't need any roads!
    <A target="_blank" HREF=http://SK-15.coloradok5.com>http://SK-15.coloradok5.com</A>
  4. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Did you try to force it out with a vice and a socket or something? The u-joint actually out? Then you have 2 directions you can push the cap.
    Ratch
    **<A target="_blank" HREF=http://k5.8m.com>http://k5.8m.com</A> What more is there to life?**
  5. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    The factory ones are the hardest to get out. B/c they're so old/been on for so long. Believe me, I know.
    You need to press it out. that's even kinda hard. But a press is your best bet.
    Boss
    <A target="_blank" HREF=http://www.boss.coloradok5.com>http://www.boss.coloradok5.com</A>
  6. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    You said the u-joint was the factory one's right? Well anyway
    I belive that the factory ones have some plastic stuff on the side of shaft that holds the u-joint cap in place. My 83,does I can see something like that giving you fits if thats the case maybe some heat or small drill bit will work.
    Just my my .02 worth hope it help's
    Highlander/ Cethern@interfold.com
    Lost? i'm not lost i'm just disorienated
  7. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    Put the heat to her! You need to weaken the plastic retainer the comes from the factory in order to remove it. Good luck.
    Why do people keep calling it a Bronco!!!!! [​IMG]
