I'm stupid, need help ASAP
Discussion in 'The Garage' started by fabjunkie, Aug 27, 2006.
  1. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    Where does the little clip go on the pads on disc brakes? I can't seem to figure it out and I'm trying to wrap up the disc swap.
  2. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    Good question... I'm about to do the same thing. I know how it was on my old pads/calipers, but the new pads seem to be different from the brief glance I took...
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    What clip?
    DO you mean the wear indicator. If so then it does not matter if you have it fwd or rear
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    or maybe the clip that goes inside the caliper piston. :dunno:
  5. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Thats the only clip I can think of.
  6. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,239
    284
    San Jose, California
    If it's the big front calipers (d44), it goes into the hollow piston cavity in the caliper. The rear caddy caliper pads come with some extra clips that don't fit anything. Is that the clip your talking about? You have to make sure to bend the tabs on the pad and use the glu to make sure it doesn't rattle around on there when it's all put together. I'm halfway done with the swap right now.
  7. fabjunkie
    Aug 23, 2005
    1,580
    Dallas Outskirts
    That was it. I found a pic on BillaVista's write up that showed a little piece of it and figured it out from there. Now I'm waiting on the wife to get back from the grocery store so I can bleed and drive it for the first time in about 5 months. :woot:
  8. fabjunkie
    Aug 23, 2005
    1,580
    Dallas Outskirts
    Well it feels good to drive her again. Still needs some more bleeding, but I'll worry about it after I swap the front over to 3/4. Don't figure I'll feel the real difference with the discs until I bleed it better.
