I'm stupid, please help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by '73 K5, Jun 21, 2000.
  1. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I\'m stupid, please help
    I'm working on my friends '91 K5 and could use some help. It's leaking ATF around the slip yoke on the rear driveshaft. So I bought a new seal, but I can't get the old seal out. I bent up the edges with a screwdriver, but it still won't budge. Needle nose plier don't help either. Anyone have any tricks. Its the seal on the very end of the tailshaft of the T-case. Thanks
    '73 K5
    Chevy good...Ford bad
  2. CBLAZER81
    CBLAZER81 1/2 ton status
    Mar 3, 2000
    281
    Milliken,COLORADO
    Re: I\'m stupid, please help
    I ended up using a slide hammer on mine.Not prettty but it worked.Just be careful not to scratch anything up too bad.
    <font color=purple>http://cblazer81.coloradok5.com</font color=purple>
  3. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    You can use a 2 or 3 prong bearing puller to get it out. The slide hammer idea is a good one too.
  4. MICHIGAN BLAZER
    MICHIGAN BLAZER 1/2 ton status
    296
    Middleville Michigan
    You can use pretty much anything you think will get it out. We had a problem getting the pinion seal out of a cherokee....used one of those brake thingys....they look like big weird forecepts. Like the others said just try no to chew up your metal
    <font color=red>MICHIGAN BLAZER
    <font color=green>89 Fullsize Blazer
    87 Cherokee
    65 IH Scout
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I think you can just unbolt the extension housing off the t-case, and punch it out from the inside.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  6. 1TUFF89
    1TUFF89 1/2 ton status
    Apr 6, 2000
    109
    West Point, Virginia
    Actually, the right way is to use a seal puller. You can get one at most hardware and automotive stores for less than eight bucks. If you don't want to spend the eight bucks to do it right you could drive a screwdriver into the outer ring of the seal itself and work it out. I've replaced all the seals in the t-case on mine when I rebuilt the case and a seal puller is cheap and works right the first time.
    Chevy's RULE!
  7. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Watch out for the oil galley inside. It looks like a rod bearing, if you chew it up the slip joint won't get lubed and you'll trash it. good luck
    creepin and crawlin
    Jim
