i'm sure it's been done but...
Discussion in 'The Garage' started by poolcues, Jun 2, 2005.
  1. poolcues
    poolcues 1/2 ton status
    Dec 13, 2004
    232
    Charlotte,NC
    i've got a rear axle and the fill plug won't budge.i rounded the inside of it so my next alternative is to take another rear diff cover and weld a fill plug on it so i can change the fluids.has anyone done this and if so got any pics.
  2. dyeager535
    26,975
    Can't you weld something to the fill plug thats stuck (like a nut) so that you can turn it out with a wrench?
    Used that trick (learned here) on a broken diff cover bolt, and it came out no problem.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You can do like Dorian said , and then replace the plug with a plug that sticks out with 4 flats for a wrench instead . I have seen both kinds of plugs on axles .
  4. gambit420s
    gambit420s 1/2 ton status
    May 17, 2005
    294
    KnoxVegas, Tennessee
    Try a #5 screw extractor. It's got LH splines that taper. Just drill through the plug completely and knock the extractor in till its tight. Then heat the diff housing a little. It should come out with a little muscle. Just be sure to CLEAN inside the housing and make sure you have a magnet in the sump.
    Ive used it on plugs in heads and blocks that had loctite, silicone, and gasket maker on the threads. but they were disassembled so a lot easier to clean up.
  5. sweetk30
    Nov 1, 2004
    25,528
    527
    horseheads , ny 14845
    take bolt that fits in the square now round. then weld it to the plug. the heat will loosen it up and help in the removal . i have done this lots of times. the bolt lets you get a socket on it.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    there is nothing wrong with adding a cover fill and drain holes. I like this idea cause its simply easier to access then the side of the diff.
  7. chevy_mud_84
    chevy_mud_84 Registered Member
    Feb 28, 2005
    89
    Brockville, ON, Canada
    Take a small ratchet extension and weld it in the plug, so that way all you gotta do is put the ratchet into the extension and the plug comes right out. thats what i did to mine, and my father did to his and my buddy. it works really well.
  8. poolcues
    Dec 13, 2004
    232
    Charlotte,NC
    a bunch of good ideas.i've welded a nut to a broken alternator bolt and that works great.guess i gotta pick the one bet for me and go with it.
