I'm truly scared
Discussion in 'The Lounge' started by mountainexplorer, May 8, 2003.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I\'m truly scared
    Its about 1:53 am. I just woke up in the middle of the night. My eyes were kind of burning and watering. When I tried opening them, they really hurt/burn. I went to the bathroom and I had really watery eyes, washed them, and eventually was able to open my eyelids, but everything is foggy now, and I'm truly scared that if I go back to sleep, I'll wake up and wont be able to see. A couple times today I saw the light of the welder, but not for long. Does blindness occur all of a sudden? Or could it just be something else. I tried washing them again, and they started burning. I wasnt in contact with any chemicals. I just had a slight headache before I went to sleep. I never really imagined how scared I was of losing my eyesight until right now. Should I go to the doctor tomorrow?
    I only hope that things wont be too foggy to read this when I wake up. /forums/images/graemlins/frown.gif
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Re: I\'m truly scared
    You sound like you have "flash burn" on your eyes. An old remedy is to take a potato, cut it in half, and lay the potato on your eyes. I know this sounds crazy, but it really does work. Some chemical in the potatoes will help heal the burn. Hope this helps.
    John
  3. potato76
    potato76 1/2 ton status
    Mar 21, 2002
    922
    phoenix, AZ
    remember when your mom told you that masturbation causes blindness.........
  4. Blaze
    Blaze 1/2 ton status
    Aug 28, 2000
    3,285
    Raleigh, NC
    SkulzNBonz is right, that potato trick works.
    If that doesn't work, maybe potato76 is right! /forums/images/graemlins/grin.gif
  5. potato76
    Mar 21, 2002
    922
    phoenix, AZ
    Of course potatoes trick is right.GEEZ.
  6. mountainexplorer
    Nov 14, 2001
    4,903
    Well, I can still see. My eyes are really sore this morning though, and not quite as clear, but not as bad as last night. So, flash burn is caused by having a glimpse at something really bright I take it. Thanks for the potato suggestion. If it starts again, I'll go find a potato. /forums/images/graemlins/grin.gif
    I'm just relieved I can still see. All I had in mind last night for some reason was what life would be like if I went blind. Just another reminder for me to be thankful for things like vision itself.
  7. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    I had a condition similar to what you are describing about 8 years ago. Is there any discharge from your eyes this morning at all (or has there been)? Is there any itching, or just burning? The condition I had was called iritis, and it presented with some of the symptoms you have exhibited. If no to the above questions, I am going to have to agree with the flash burn. That sucks too.
  8. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    The light produced by the arc is enough to give unprotected skin a sunburn in seconds, so when the naked eye is exposed it does the same...to the surface of your eye. The radiation will actually blister the surface of the eye (the blisters are very tiny) and it'll feel like someone dumped a handful of hot sand into your eye, except you can't wash it out.
    Generally the first symptoms show up 8-10 hours after you've been flashed and can last from a few hours of mild discomfort to a few days of agony.
    You will likely find that your eyes are quite photo-sensitive for a few days after as well. Good dark sun glasses help if you have to be outside.
    I've tried the potato trick, I've tried damp tea bags (works better than potato IMO) but by far the best is to go see a doctor and get him to drop in a few freezing drops /forums/images/graemlins/thumb.gif I find the hardest thing to do with a bad flash is sleep...a few drops of freezing usually gives you enough time to fall asleep.
    Don't look at the arc unless you have a helmet on!!
    You have my sympathy, getting a welders flash isn't something I'd wish on anyone!
    Rene
  9. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    That happened to me once, but not quite so serious. I was welding at my dads shop during college, and long story short, we're trying to fill some orders late in the evening when I forgot to flip my helmot down (1 second). Thank the Lord for auto-darkening now.
    /forums/images/graemlins/smirk.gif
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    I've experienced that 3 times in my life so far. Not fun. All 3 times it happened, I was awakened in the middle of the night with the burning sensation and watery eyes. Just could not open my eyes and they hurt like hell. And each of those instances did happen with me catching a glimps of a welding flash.
    I'm very careful now around flashes as I'm around a welding shop everyday at work. I go so far to put my hand up to block the flash whenever I walk by them. Its just not worth going thru another night of restless and painful sleep. /forums/images/graemlins/frown.gif
  11. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    And closing your eyes just to tack something into place is also a bad idea.... /forums/images/graemlins/deal.gif
  12. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    I've worked in about a dozen different fab shops and I could probably count on one hand the number of guys that religously use their helmet when tacking. Over 95% of 'fitters' tacking stuff together will do so without a helmet...myself included.
    A welding helmet is for welding...not tacking/forums/images/graemlins/smile.gif
    In 16 years I have never had a flash from tacking...every flash I've had was when working in close quarters with another welder. Most come from the side rather than from looking directly at the arc.
    That being said...I would recomend using the helmet even when tacking (do what I say not what I do. /forums/images/graemlins/rolleyes.gif/forums/images/graemlins/grin.gif)
    Rene
  13. chevyfumes
    Feb 24, 2000
    38,584
    266
    I never use a helmet for tacking either, but I do look away and close my eyes, don't wanna get a sun burnt face ya know.... /forums/images/graemlins/thumb.gif
  14. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    There are quite a few techniques for avoiding the welders sun tan.../forums/images/graemlins/rotfl.gif but occasionally it happens.
    It's just way too much trouble to bother with the helmet when trying to hold the parts, position the gun, and then tack it exactly where you want it...too often as soon as you flip the helmet down the sh!t moves. Auto darkening helmets are great for home, but generally they suck in a shop.
    Rene
  15. mountainexplorer
    Nov 14, 2001
    4,903
    That sounds exactly like what it felt like to me. Thanks for the input everyone.
    With the exception of a slight headache, I can see pretty much normally now.
  16. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Flashburn in the eye's, feel's like a dumptruck has unloaded mass quantity's of gravel in Your eye's. It'll quit hurting, and be better in about 6 hour's afterward's.
    In the meantime, don't try reading in bed, it won't help. /forums/images/graemlins/eek.gif
  17. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    I flash burned My eyes back in high school in welding class. I have been the proud /forums/images/graemlins/rolleyes.gif owner of glasses every since. /forums/images/graemlins/mad.gif
  18. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    I'd wager that was coincedence Corey...having flashed myself at least a dozen times in 16 years (maybe more.../forums/images/graemlins/eek.gif) my eyesight has not deteriorated any.
    Rene
  19. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    when I was in highschool my friend and I decided to build a gokart, and while we were welding on it I got the worst sunburn from it. We were welding with short sleeves and I only had on a set of goggles with a welding lense in them, so my whole face got burnt too. It felt like somebody was trying to pull my lips off of my face while scrubbing me with sandpaper. Needless to say I always use a full mask and long sleeves now...
  20. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    If you get burnt, go to the pharmacy and get some ocu-hist eye drops. They used to be prescription but you can get em OTC now, though they might be under a different name. Only times i've seen people get flash are working alongside someone else for a long period of time, or if you're really unlucky, using a cracked filter lens.
