Impending move: ship truck and boat 1800 miles or drive the rig?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by smack, Jan 20, 2003.
  1. smack
    smack 1/2 ton status
    Feb 24, 2000
    277
    Colorado
    I'm about to move back to Colorado from NY but I can't decide what to do.
    I would have to pull a single axle 23 foot boat with my Jimmy for almost 2000 miles!
    Driveline vibs aside, would you guys do it???
    So far I've gotten transport quotes for the Jimmy at around 800 and the boat for 1600. That's $2400!!!
    I figure, without the boat I'd need about $350 in gas alone.
    Suggestions!!!
  2. dyeager535
    26,975
    I decided to drive my '83 K5 cross country, besides lodging, food and gas, it cost me $500 to have the 208 rebuilt in NC, and $1500 to have the 700R4 rebuilt in Arizona /forums/images/graemlins/smile.gif
    If you have faith in your parts, theres no reason to NOT drive them, but if you aren't quite sure, theres nothing worse than being on the road and having something major fail, because there is nothing you can do about it, and no time to fix it yourself.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I would do it no problem. I have done some long distance towing in my K5. I tow my boat (18 foot 2500 lbs single axle trailer) to the coast and back every summer (1400 miles). It goes just fine
    Just make sure your rig is in good condition and any mechanical issues are throughly checked out and taken care of. Change all the fluids, Make sure the cooling system is in good shape, Have spare tires for truck and trailer and lube the bearings. Have the boat properly loaded/centered on the trailer and lighten it up as much as possible.
    But if you dont trust your rig to make the trip it might be better to have it transported.
  4. tRustyK5
    Jul 23, 2000
    36,166
    1,364
    E-town baby!
    Drive it...you don't have a 700R-4 to worry about. Like Thunder said check all the fluids and make sure you have tools and spare tires for the truck and the trailer.
    Rene
  5. dyeager535
    26,975
    Whoops. I shoulda looked at his specs! 465, drive it!
  6. smack
    Feb 24, 2000
    277
    Colorado
    "Just make sure your rig is in good condition and any mechanical issues are throughly checked out and taken care of"
    Well, see, there's the kicker. I DO have a driveline vibration I can't seem to work out. Truck has a strange lift, but I just got a brand new driveshaft for the rear to eliminate the conversion u-joint. No vibs for 200 miles than they started again. Don't know if it's in the tranny, tcase, or what. Plus I'm sure my driveline angles aren't perfect.
    With all that would you still go for it???
  7. tRustyK5
    Jul 23, 2000
    36,166
    1,364
    E-town baby!
    Bring a few spare U-joints...they're easy to change. Just check em every time you fuel up and if it looks like a joint is on it's way out swap a new one in.
    I'd guess you're not leaving tomorrow though so it might just be better to fix the vibe before you leave. The angle that the upper and lower joint operate at should be close to equal. I tipped my pinion upwards towards the t-case a bit from that and have no vibes...
    Have you dropped the T-case down any?
    rene
  8. smack
    Feb 24, 2000
    277
    Colorado
    How did you tip it? If you shimed it where you get 'em and how did you measure how much??
    In my case I'd have to tip the dif DOWN!!!
  9. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I'd look at the spring pack and see what the wedges look like...ya might be able to just take it out..maybe...just a thought...how soon are ya gonna be makin' the trip?
  10. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    I drove my travel trailer and pickup 1800 miles from AB to MO no problem, then I went back a few months later and drove the K5 back in 2 days. Should be no problem
  11. tRustyK5
    Jul 23, 2000
    36,166
    1,364
    E-town baby!
    Just try for equal operating angles by dropping the t-case down and adjusting the diff to suit. I got a selection of shims from a local spring shop, they're not that spendy.
    Rene
  12. smack
    Feb 24, 2000
    277
    Colorado
    There are wedges there already??
  13. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    One thing I would do is Take the K5 to a good offroad
    shop pay them to tell you what needs to be done to fix the vibration then fix it your self. And always check double check
    and triple check everything on the K5 and you should be ok.
    I tell you nothing is worse tan being broke down on the highway no parts and K5's dont fit very well on a U-Haul trailer.
    good luck,
    Bo
  14. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    never heard of an offroad shop, thats a new one, interesting
    i gonna have to make same type of decision when i decide to buy a K5 sometime this year across the country most likely,. either go and drive back or ship,,
    like beforementioned Id make sure the 5 is mechanically sound and not using or losing any fluids or doing anything unusual as far as its running state
    when you plan on doing the trip and what highways across the midewest you gonna be taking probably ?
    good luck
  15. K5Jimmy
    Sep 21, 2000
    1,141
    I'm asking if there is some sorta wedge in there already...since it's an 87, the 12B was swapped in...some pieces may have been installed/reinstalled from one truck to another unnecessarily...I'm understanding that the yoke is pointed up at a more extreme angle than seems appropriate...if the truck has no lift, the yoke would be more or less parallel to the ground...
  16. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    I'm moving from CA to NH soon.....I've got to move TWO Blazers..... Why don't we figure out a way to rent a big trailer for ALL of them and split the cost!!!????
    /forums/images/graemlins/thumb.gif
  17. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    My 87 use to pull a 26' rv from Indiana over the mountains to NC shores every summer till we got the new pickup. Shouldn't be to bad one way if you do the maintance/tune-ups before you leave /forums/images/graemlins/thumb.gif
  18. BigBen
    BigBen 1/2 ton status Premium Member
    Nov 14, 2002
    1,194
    Grand Haven, MI
    Jeeze, I'm glad to hear I'm not alone.
    I'm moving my K5 from Cali to Michigan in March/April......
  19. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Cool!
    How many trucks do you need to move....? Sounds like we'll have a "full load" at this rate!!!
  20. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    "The happiest day in a boat owner's life is the day he sells it." /forums/images/graemlins/rotfl.gif
