Improper Alternator,battery,or ?????
Discussion in 'The Garage' started by mobyduck, Dec 28, 2006.
  1. mobyduck
    mobyduck Newbie
    Dec 26, 2006
    3
    Carthage, N.C.
    I bought an 86'K5 Loaded 305.5.0 to pull my 22ft.cabin cruiser,wasn't enough H.P.so I found an 76'Camero with a 350.5.7 w/57,000m.Switched motors,man what a difference!!!! Problem is,,Camero wasn't loaded and the alternater,I am assuming was smaller than original one that came on the K-5.Problem is ,, I was having the same problem before I switched motors.I cant leave the K-5 running with the lights on and/or the heater fan running for any legnth of time or it kills my battery. Amp gauge seems to be working properly. Put a new 900 ca.diehard battery in,, no change.It just will not put out a charge when idle.Idle is set proper. Thinking the alt. was changed and replaced with maybe a smaller one before I bought it.
    Does anyone know what the proper amp alternator should be and what the proper cca battery should be for a 86'K5 loaded with a 350. 5.7 not a 305.5.0 ?Thanks,
    MobyDuck
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Doesn't matter what is supposed to be in there , upgrade . Get a police or tow package alternator from the timeframe your truck was made , and the biggest CCA battery that will fit .
    Almost all the performance mail order shops have alternators too . Don't get a one wire though , get the 3 wire one .
  3. bandit4369
    bandit4369 Registered Member
    Mar 20, 2006
    82
    Nw. Pa.
    Take the alternator to one of the chain parts stores and have it tested. If it tests good then you have a wiring problem. If it tests bad, buy one... problem solved.
