Improved braking
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CarolinaBogger, Feb 14, 2002.
  1. CarolinaBogger
    CarolinaBogger Registered Member
    Apr 17, 2000
    86
    Boone, NC
    What can you do to improve braking. I've got a rear disc brake conversion on the way, but was wondering if there were other ways to improve braking, like new master cyl., bigger/stronger front calipers, etc...
    Thanks yall
    <font color=green>"I'm old enough to know better, but I'm still to young to care!"</font color=green>
  2. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    Bolt on a 14 bolt with 1 ton drums. Your braking will improve 5 times over
    Surfing is Life...
  3. CarolinaBogger
    Apr 17, 2000
    86
    Boone, NC
    Well, the 14 bolt is in the garage waiting for money for an overhaul, so it'll probably be a while for that. How bout the front end? Can you get new caliper with more pistons that would bolt up?
  4. dyeager535
    26,982
    191
    You'd need a bigger rotor with more surface area. Not sure where you are going to find one for a truck, since I have no idea what size a 10 bolt vs say a Dana 60 rotor is, and if they could even be interchanged, along with the calipers.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  5. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    www.jmartin.net/goose
  6. dyeager535
    26,982
    191
    Heh, for that price, might as well get a Dana 60 and hope it comes with bigger brakes lol.
    Dorian
  7. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Not sure if it helps, but there is a company out there called Wilwood (www.wilwood.com). You name it, they'll make it. They are a bit pricey, but they are very high performance and can make your rig stop on a dime and give you change. I haven't put them on my Blazer, but their 4 wheel disc setup was awsome on my 68 chevelle.
  8. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    There's a HD 3/4T truck caliper that has a large piston that might help you out, it should give better clamping pressure and still fit in the stock mounts. The only other way is to go to a bigger rotor and that means 3/4 or 1-ton axles. It also means you have to go to bigger wheels to get the brakes to fit inside them.
    I think your 3/4T swap is the best place to drop money.
    Be aware that the 14 bolt's bigger brakes will help but on a lifted short wheelbase vehicle (like a K5) the front axle will do the majority of your stopping for you. You will likely need to put in an adjustable proportioning valve to turn them down! When I added my 3/4T axles the first time I had way too much rear brake, and that was with 32" tires and 3" of lift.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
  9. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I swapped my vacuum booster for a hydra-booster. My brakes are at least 50% more responsive, less resistance and not effected by low manifold vacuum like big cames create. I'd do it again in a heartbeat.
    I started with nothing and I still have most of that left! - <a target="_blank" href=http://community.webshots.com/user/borregok5> Pictures</a>
  10. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    You can get the 13" rotors from a 79 3/4 ton PU and then put a 1 ton MC on. With this setup my K5 would stop on a dime and it had 36" TSL's.
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
