Improving 305 Performance
Discussion in 'The Garage' started by prossett, Sep 16, 2006.
  1. prossett
    prossett 1/2 ton status
    Sep 29, 2005
    165
    United Arab Emirates
    I run a 1983 Jimmy in sand dunes - awesome truck! - but I'd like to get a little more out of my 305 small block.
    I have headers and removed the cat, and I flip my air intake cover to let more air in... but other than that everything is stock, and it runs sweet.
    What can I do to get more power?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    change the cam.
  3. prossett
    Sep 29, 2005
    165
    Thanks - sounds like a good mod, and cheap (Summit Racing cams start at $50) but what can I expect as a gain?
    I know you can't say exactly, but would you say it's a "Wow!', a 'OK then' or a 'Well, barely felt that'...?
  4. rtrotter
    rtrotter Registered Member
    Jun 15, 2006
    34
    Wichita, KS
    It depends on the cam setup you get. Some packages are set up for hauling and low-range torque, and some are set up for highway use (better mid-range HP and throttle response). You will normally feel a noticeable difference with throttle response and acceleration, and depending on the cam, up to about a 5% to 8% HP increase on stock heads. Not bad for a $300 cam setup.
    Heads will make a huge difference, but they're pricey.
    BTW, I'm in UAE right now.
    Rob
  5. prossett
    Sep 29, 2005
    165
    Really? Come visit our local chapter of 4x4 crazies - Dubai4x4.com, I'm PR there. Not many GMCs, in fact I think I'm the only guy with an old GMC. It sure gets noticed!!! :)
    So the cams I see listed at SummitRacing.com give me a choice of rpm range, duration and lift... I climb amazing long friggin steep dunes, so I reckon I would need the cam designed for high engine screaming - that would be something like this?
    RPM range: 2200-5700
    Duration: 224/234
    Lift: .465/.488
    I don't have a rpm gauge, but basically I floor it and then release a bit, so I've got to be in the 5000rpm range as I start the climb, then it kind of drops until I either stop or make the turn up top.
    The low rpm ones listed start at 1000-3000 rpm, and the highest are 4000-7200 rpm.
  6. rtrotter
    Jun 15, 2006
    34
    Wichita, KS
    From what I've seen over here with the little pocket cars and luxury cars, I'll bet you stand out! Unfortunately, I'm stuck on the Air Base here, but I'll definately check out your site.
    As for the cam, I've never climbed a sand dune, but I'd imagine you'd need a lot of sustained torque in the low-rpm range, so you would want a cam designed for some serious low-range torque.
    Rob
  7. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,727
    109
    earth
    hmmm I had a led sled with a 350 4bl that I put a 350 lift with a 292 duration in with roller rockers and a dbl timing chain in and it screamed! I compare a 1974 Chevy impala station wagon to our Blazers. Now if you don't care about mileage ;)
  8. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    three words 383
  9. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    491
    New Hampshire
    I recomend going for one of Summits packages that gives you a cam, intake, carb, and everything needed to put it together. The best deals and it would greatly improve your power.
    I think the best cams out there are the Lunati Voodoo cams because of the power they make and wide power band they create. But are a little more coin than Summit cams.
    Also think about upgrading your ignition. I have a Pertronix Flame Thrower 50,000 volt coil and ignition module, with a Moroso cap and wires. The throttle responce I got out of was well worth the $$. Also get new spark plugs, stock ones work the best surprisingly.
    Also if you don't want to do a cam you go with 1.6 rocker arms over the 1.5 stock rocker arms. Gives you more lift, gives you more power.
  10. 02turbogixxer
    02turbogixxer Registered Member
    Aug 1, 2006
    63
    Dallas, TX
    Thats 3 numbers not words. :D
  11. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    Technically just one number.:doah:
  12. prossett
    Sep 29, 2005
    165
    OK, let's settle this so I can work more ponies out of my 305:
    383 can be three or five words if spoken, three digits or one number, and if written on a check it's one word. It can also be interesting to note that it reads the same backwards.
    Now, if we're done with the trivial - a Summit package sounds like a good idea, thanks.
    So, we've got:
    intake manifold + cam and lifters package
    distributor, wires, plugs
    Does anybody know of a complete heads package for 305 similar to http://store.summitracing.com/partdetail.asp?part=EDL%2D2098&N=700+0&autoview=sku Summit told me it wouldn't fit 305 and had no other suggestions, which kind of sucked.
    BTW, here's the dunes I drive: http://www.dubai4x4.com/albums/albuo45/Climb_Resize.jpg
    http://www.dubai4x4.com/albums/albuo45/Along_Resized.jpg
    http://www.dubai4x4.com/albums/albuo45/Turn.jpg
    I know, not the k5's most suitable environment, but my beauty holds its own and often kicks sand up the nose of much younger cars!!
  13. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Some answers might presuppose that you are have the average CK5-poster shoestring wallet, which may not be the case. What kind of a budget did you foresee laying out on this power upgrade? Would something like this be do-able for you? This is the same engine at Summit.
  14. rtrotter
    Jun 15, 2006
    34
    Wichita, KS
  15. Chevy305
    Jan 23, 2006
    11,232
    491
    New Hampshire
