Improving Low End Torque and Overall Power to my '79 Blazer?
Discussion in 'The Garage' started by m1ndless, Feb 21, 2007.
  1. m1ndless
    m1ndless Banned
    Feb 18, 2007
    642
    Phoenix, AZ
    I am looking to improve low end torque and overall power to my '79 blazer, it has the 5.7L 350 as far as I can tell. I am thinking new intake manifold and 4 barrell carb?
  2. WantedaDodge
    WantedaDodge 1/2 ton status
    Dec 16, 2004
    282
    Eugene, OR
    yea, a new cam would help a lot as well, but they are kind of a pain to swap in truck, imho...
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    134
    You have to give us a budget. How much are you looking to do?
  4. WantedaDodge
    Dec 16, 2004
    282
    Eugene, OR
    Playing with ignition timing might help a lot too
  5. AFUFO
    AFUFO 1/2 ton status
    Apr 26, 2006
    329
    Chesapeake,Virginia
    Could swap out gears too for some slightly lower. But you would reduce topend speed and gas milage at high speed.
    Have you checked out edelbrocks power packages?
  6. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    freeflowing exhaust, cam intake & carb, heads, gears, flux capacitor, etc, etc.....
  7. TheAustrian
    TheAustrian 1/2 ton status
    Jun 20, 2006
    160
    Austria
    get you a edelbrock performer package (cam, air intagake and 500/650 carb), put on some long tube headers and a true dual exhaust system with at least 2 1/4". You can also add new power sparks, ignition cables and maybe a new H.E.I ignition. This should push it up to a little over 200 hp and good for 400 nm. I did these modifications to my '79 Blazer and it runs great. The next weeks I'm going to swap my diff gears from 3.73's to 4.56's. I hope that will be okay with my 35's Baja Belted.
  8. 80' 427
    80' 427 1/2 ton status Premium Member
    Nov 14, 2006
    4,089
    400
    NEBRASKA
    I think the biggest change you can make it to regear. Even with a built motor if it is out of the power band it will be a dog. In my 84 I went from a 305 with 3.08s and 235 75s to 4.11s and 33s and it made a huge difference. Sure it won't do 150 mph ( hey with the 700 it had a final drive of 2.15), but who needs to ever go faster than a 100 in a truck. Plus the mpg actually went up because it doesn't lug the engine. Now it has a mild 350 and really has good power.
  9. m1ndless
    m1ndless Banned
    Feb 18, 2007
    642
    Phoenix, AZ
    I may not know alot about cars, but I aint that retarded. :D
  10. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    before i add or swap parts, i examine what i already have to work with. is the carb setup, timing, fuel pressure, plug gap, etc. most of that stuff won't give you real power gains, but can help drivability issues, like improving throttle response.
    be careful if you regear. you still need to be able to hit 88mph for the flux capacitor to work.
  11. m1ndless
    m1ndless Banned
    Feb 18, 2007
    642
    Phoenix, AZ
    Lol. I am going to do the work in parts, I was looking at the Edlebrock power kit thingy, its like 1700, I planned on doing it in pieces, so I am going to hold off on that, plus my heads are pretty new already, the engine was rebuild 2 years ago, and new heads were put on at that time.
  12. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    headers will be your best bet... performance begins with the exhaust... Be aware, you'll get what you pay for...
  13. bigblaza
    bigblaza Registered Member
    Jan 16, 2007
    65
    Maryland
    X2!!!
  14. m1ndless
    m1ndless Banned
    Feb 18, 2007
    642
    Phoenix, AZ
    So headers first? Then RV Cam? Then...? I want decent MPG cause I have to drive about an hour to get to where we take our quads too. I need to get my gas gauge fixed, it says "e" all the time :(
  15. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    yup, exhaust first.. I'd go over the topend all at once, do the cam, intake and carb at the same time..
    Don't forget, a proper tune is the most critical factor..
    What are your plans for tire size? it matters...
  16. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    :haha: :haha:
    and nitrogen rectifiers, new muffler bearings, and shock shims
  17. m1ndless
    m1ndless Banned
    Feb 18, 2007
    642
    Phoenix, AZ
    I didn't realize being a immature dickhead was funny?
  18. m1ndless
    m1ndless Banned
    Feb 18, 2007
    642
    Phoenix, AZ
  19. 76zimmer
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    Allright lighten up Francis.....
    you need to have a sense of humor.
    Anyhow unless you plan on running 6 grand go with some 1.5 diameter primaries into about a 2.5 to 3" collector, the longer the tube the better for torque. Then run 2.5 duals through some turbo mufflers of some kind.
    Then work on the cam.....CALL a cam manufacturer and tell them exactly what you would like to do with the vehicle, have your tire size, gear ratio, trans type, heads, C.R., carb size, etc. They can tell you what will work best.
    Good luck, and WELCOME
  20. m1ndless
    m1ndless Banned
    Feb 18, 2007
    642
    Phoenix, AZ
    Haha I was just ****in' around. I like to pretend to be all serious.
    Can you just reccomend some Headers? I am not sure what to look for..
    And what are soem CAM manufacters I should call?
