In a little debate here
Discussion in 'The Garage' started by Brians89K5, Apr 25, 2006.
  1. Brians89K5
    Brians89K5 1/2 ton status
    Jan 4, 2006
    535
    Rialto Ca.
    Im going back and fourth on replacing my rear drive shaft or having it lenghtened. I just lifted my truck 6 inches and I need to make it longer. Im also waffling back and fourth on a cv drive line or just set up what I have. What are you fellas doing on your six inch lift? Right not, it vibrates a little.... well... A lot... :eek1:
    ~Brian
  2. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    I lifted mine 4" and intalled a new shaft w/ CV joint. Works great.
  3. BizeeB65
    BizeeB65 1/2 ton status
    Oct 12, 2005
    859
    Louisville, KY
    What driveline are you running? I am looking at used driveshafts after my swap, but I imagine running into rear driveline problems since the rear output is longer on a 205 than a 203. Therefore I will probably have to goto a cv style rear for my setup. :dunno:
  4. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    If your running a slip yolk (which you probably are if its an 89 blazer), then you probably need to lengthen the shaft and have a cv joint installed. I put around 6" lift on my 87 with a slip yolk and it had a horrible vibration. The shaft was too short and had no cv, so the driveshaft was actually moving around inside the slip yolk. Thats what was causing my vibration/grinding noise. Search around on here and you can figure out how to measure your driveshaft so that you lengthen it the right length. Too long and it can bottom out in the tcase and crack the aluminum case....too short and it can pull out. You get the idea.
    -Harrison
