in. lb torque wrench
Discussion in 'The Tool Shed' started by sunnyc123abc, Feb 24, 2006.
  1. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    since i dont have a in. lb. torque wrench, can i just convert it to ft. and use my ft.lb. torque wrench? thanks
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    If your ft/lb one goes low enough but most don't. My lowest snap-on ft/lb one starts at 5ft/lb which is 60in/lb. Most measurements calling for in/lb are lower than that.
  3. sunnyc123abc
    Mar 12, 2005
    636
    SoCal
    yea, ur right. I just looked at it and it starts at 5. Is there any other way i can measure the preload of the pinion without at torque wrench?
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    preload on your pinion should be a with a beam type torque wrench and I think spec is in ft-lbs on most... a click type is useless for measuring pinion preload.
  5. sunnyc123abc
    Mar 12, 2005
    636
    SoCal
    is it really in ft. lbs, cause i read it has to be from 12 to 14 in. lbs.
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    It is in/lb on the pinion. I just did it by feel as I only have a click type in/lb wrench. 12-14 in/lb is really just taking up all slack and then leaving it with a very light drag. Ideally see if you can rent/borrow a beam type wrench.
  7. JpEater
    JpEater 1/2 ton status
    Nov 20, 2005
    299
    Augusta, Georgia
    feel what the drag is like before you tear it down and you will know what to feel for when putting it together. When you know what to feel for then getting the beam wrench out of the box is a waste of time.
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
  9. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    yes, a fish scale.... make sure it is accurate by hanging a known weight on it. should be easy enough to find one that is in ounces. now ya get to do the math. have to turn ounces into fractions of a Lbs, then turn that measurement into inches. not hard really. should also only cost about 5 bucks at walmart
    oh, make sure you pull in a STRAIGHT PLANE.
    the correct tool for the same use i described above is a pus pull gauge. they can be spendy though. hardest part about a fish scale is watching it to see the reading before it moves, the push pull gauge has a second needle that stays at the max.
    Grant
  10. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Good to see you haven't given up on the K5.:D
  11. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    If you are close to Temecula I can let you borrow mine
  12. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Or, a trigger pull guage like those sold by RCBS. They are probably more accurate than a fish scale, and they have a little pointer that holds the reading for ya. I think they run around $20 or so. After you set up your gears, you can go put hair triggers on yer favorite firearms. I couldnt believe the prices for dial in/lb torque wrenches. I managed to find one for cheap that will do up to 30 in/lb. I think it cost me $60 or so. If you want the brand I'll have to run downstairs.
  13. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Psst... Scroll up a few posts... ;) $37.50 plus shipping.
  14. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    DOH! I wish I had found that one when I was looking, I got a dial type, cost more, but comes with a nice blow-molded case with tight fitting foam inside, and it comes with a calibration spec sheet.
