in need of 208 shifter linkage pics
Discussion in 'The Garage' started by 55Willy, Mar 25, 2007.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    My 208 is without any add ones so I'm trying to build some linkage for it. I'm guessing the forward pivot was actually part of the shifter?
    I just need to make sure I make this thing shift the right way.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The 208 is easiest to make linkage for . It just goes forward and back like a transmission shifter . The factory has a little side motion to clear the stop before you can go into low , but the case itself just has a normal detent lever .
    I took a snapshot out of a pdf file I have :
  3. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    thanks so when set up right, as you pull back on the shifter the tranny linkage goes forward and vise versa if ya push forward on the shifter?
  4. 85mudbogger
    85mudbogger 1/2 ton status
    Feb 5, 2007
    226
    missouri
    yes its just a threaded rod so u can make it longer or shorter for adjustability and u hit the nail on the head, pull back on shifter and t case shifts forward to 4 low and push forward on shifter and t case shifts back to 2hi
