In-Side Lights?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by WakeBoard&4X4er, Nov 22, 2000.
  1. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    I have a 1991 K5 Blazer, and non of the in-side lights (not dash or by the 4X$ shfiter) come on when the doors open, or turn then on with the light switch on the dash. Is there just one light in the top? or are there some at the floor also. Thanks All!
    brettmcox.coloradok5.com
  2. ohio_frotyk5
    ohio_frotyk5 Registered Member
    Aug 2, 2000
    13
    OOOOOOhio
    Hello. There should be lights behind the dash, under the cigarette tray (change holder), one in the middle of roof between seats, one in the rear on drivers side, and the 4x shift indicator should light up. The only ones that light up while the door opens should be the one under the ash tray, one up on the roof between the seats and the one in the rear on the drivers side. I dont know whys your dont work but atleast you know what lights work when there supposed to.
    Ricky
  3. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    There is a switch on the inside of the door frame that turns the lights on or off. Sometimes they stick closed and need some WD-40 or something to unstick it. Or the wiring could have a short or corroded and may need to be looked at.
    Communication Breakdown
    74 Blazer
    Zeppelin
