In stock:3:1 NP205 Lomax
Discussion in 'The Garage' started by Lomax, Jan 30, 2006.
  1. Lomax
    Lomax Registered Member
    Sep 26, 2002
    15
    This message is to respond to the many posts regarding the NP205 low gears. The 32 spline kits (case and full gear set) are in stock and shipping out. The package includes a new nodular iron case and full HD gear set. Price is $1400.00. Contact JB Conversions, Inc. at 337-625-2379 or visit www.jbconversions.com.
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    holy crap, your kidding me! they are finally for sale!:rolleyes::eek1::doah:
  3. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    holy smokes batman
  4. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    You are my new favorite person! :thumb:
    Congrats on getting this thing out, and at a reasonable price too. Just a quick question: When you call it a 3:1 gearset, is it truly 3.000:1 or is it something more like 3.10:1 or 2.90:1??? I know, it sounds like splitting hairs but I was just curious since I'm frantically rebuilding my gear and crawl ratio tables in Excel to see just how this announcement affects my build plans. :D
    Also, perhaps it's implied in the message above, but is this a complete "bolt in" transfercase...or do other parts still need to be added to finish it?
    :usaflag:
  5. Lomax
    Sep 26, 2002
    15
    205 3:1 tcase
    The new case is passenger side front output. The case has both the round pattern and 8 bolt. The round pattern has two choices of holes in case you want to raise the front output. The case will mount to any adapter already suited to a GM case. No special adapters are required beyond that required to mount a stock GM 205. You transfer your output shafts, shift rails, forks, and bearing retainers from your case to the LoMax case. We will be stocking new replacement front output shafts (32 spline) in a few weeks. The front output shafts should have been in by now but they are running behind. We can also provide bearings, seals, etc..
    The ratio is right on at 3:1. The gears are a bit wider than stock to accommodate the lower ratio however the overall length of the case is the same as stock.
  6. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    It looks like we are supplying the output gears (no biggee), but what about the input gear. If you are supplying it, is it the short or long 32 spline input???
    I just looked, and it looks like the short 32 spline. Any chance of getting a long 32 spline input as that will be what I need?
  7. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Great news...... :waytogo: My hats off to ya... you should sell alot of 'em.
    What is the shifter setup. Can you isolate front only (hi/low) and rear only (hi/low)...? :ears:
    Marv
  8. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Anything more than a "snowballs chance in hell" that this will someday be offered in a driver's side drop??? :crazy:
    Mog 404s are opposite of traditional Chevy.....and that's what I'm using on my current project.
    I have some rather "unsexy" alternatives to try to move the pumpkin to the Chevy side....so I figure I'd at least ask the unpopular question now and get it over with.
    :usaflag:
  9. Lomax
    Sep 26, 2002
    15
    shifting
    The new case offers the same shifting options as a stock case. We did not modify the shift shaft bores or cross pin bores. Twin stick modifications are done to the shift rails identically for our case or a stock case.
    Ford cases will come later; if the GM cases sell well.
  10. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Good to hear :thumb:.....I was trying not to use the "F" word, but I guess that's really what I was talking about.
    Could your "GM case version" be run upside down to achieve the same effect (immediate thoughts are that the linkages would be an issue, and it might also leak like a seive!)
    BTW -> I'm loving the idea of a 9.3:1 doubled low range (187:1 and 125:1 crawl ratios), being able to run 7.56 axle gears and still turn only 2100 RPMs at 65MPH on the highway!
    :usaflag:
