in the middle of a cam swap and need HELP!!!!!!ANOTHER QUESTION
Discussion in 'The Garage' started by AnthonyG, Apr 4, 2003.
  1. AnthonyG
    AnthonyG 1/2 ton status
    Jan 26, 2003
    339
    Gillette Wyoming
    I can't get the intake off I have all the bolts i can see off (6 on each) side what could be holding it I can move it all the way around but it just won't come off I don't want to break my nice weiand intake
  2. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    Re: in the middle of a cam swap and need HELP!!!!!!
    Get a screwdriver and tap it between the bottom of the intake and the block Just above the timing chain cover pry gently it'll come loose
  3. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    The oil pressure sending unit mat be in the way. At the rear top of the block. I hope you have the distributor out.. LOL.
    John
  4. Rusty68
    Rusty68 1/2 ton status
    Jan 22, 2003
    116
    Elko, Nevada
    Also as kind of a for warning, the timing cover also has 2 bolts, 1 on each side going threw the oil pan. Putting the cover back on without pulling the pan is a bear. They always seem to leak
  5. AnthonyG
    Jan 26, 2003
    339
    Gillette Wyoming
    that was it thanks I thought that was the the way to do it but this beeing my firse dive that far into a motor by my self I though it would be better to ask.
    Is there a special way to do so that it doesn't leak
  6. Rusty68
    Jan 22, 2003
    116
    Elko, Nevada
    You stand about a 20% chance of it not leaking if you dont pull the pan. It is difficult to not tweak the thin cover when your pull it off. Dont force anything. Also when you pull the harmonic balancer, make sure you put a bolt in the end of the crank so you dont ruin the threads.
  7. AnthonyG
    Jan 26, 2003
    339
    Gillette Wyoming
    /forums/images/graemlins/1zhelp.gifI am to the piont were i am pulling the cam out and it comes out to were i can see the first 3 or 4 lobes and then nothing It will not come any farther it is like it is stuck
    it will go back in but not all the way I don't want to force it What do i do /forums/images/graemlins/1zhelp.gif
  8. Rusty68
    Jan 22, 2003
    116
    Elko, Nevada
    you need to pull the fuel pump off so you can get the drive rod out
  9. AnthonyG
    Jan 26, 2003
    339
    Gillette Wyoming
    OOOOOOOOHHHHHHHHH that would make sence /forums/images/graemlins/thumb.gif
    thanks you da man /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  10. AnthonyG
    Jan 26, 2003
    339
    Gillette Wyoming
    Thanks everybody It worked now all i have to do is clean up the surfusses and put it all back together I think i will drop the pan in order to put the timing cover back on.
    I was wondering if there is any way to pull the bottom timing sprocket with out a puller I have a puller for the harmonic balencer but not one for tha gear any ideas??
    I am going to a double roller setup also how much play should there be in the timing chain I think mine might have jumped a gear
    once again thanks for all the help
  11. Rusty68
    Jan 22, 2003
    116
    Elko, Nevada
    The chain should have about 1/2 play with normal miles on it. But the double roller/heavy duty type can be had for about 25 bucks at napa or the like. I have heard of people giving the gear a couple wacks with a chisel and cracking it thereby letting it just slip off. But the puller way is much more easy. I would also recomend going and getting a long bolt and nut that fits in the end of your crankshaft. This could be used to push the balancer back on. I had a friend beat his on with a hammer and block of wood after a timing gear swap. His motor began knocking the next day from a ruined thrust bearing. somthing to think about
  12. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    This might help. /forums/images/graemlins/thumb.gif
    Cam Change
  13. AnthonyG
    Jan 26, 2003
    339
    Gillette Wyoming
    thanks but I already have that. thats what i used for most of it, it was VERY helpfull I just needed help with a few parts that it didn't cover
