In The Midle Of A Lift. Help!!!!
Discussion in 'The Garage' started by NoReGrEtS, Mar 16, 2006.
  1. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    sorry for not useing the search but Im lifting my truck and dont have time to read thruogh stuff. I need a part number for longer front brake hose thought I could get it to work but I cant. and how the hell do you get the steering arm off? I will check back in a little bit
    thanks Shawn
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I just got some superlift extended brake lines and the steering arm I have had the best luck with a torch and a BFH.
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yeah BFH for the steering arm. Hit down not up it should pop the conical washers loose. The try and grab them and pull them off. Once you get them out it's usually pretty easy.
    Part # 38873 at napa for brake lines. It's about 26" long. I paid $32 for the pair.
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    As people said a BFH. Hit down. I use big o'l a wood spliting maul. One or 2 hits and everything is loose...........Or broke:D
  5. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    is that for a d44, 10b or d60? i'm not familiar with differences in the brake lines/fittings.
  6. NoReGrEtS
    Nov 7, 2005
    848
    Thanks guys
    and by the way its a 6" rough ride springs all around and 12bolt rear and 10 bolt front
    thanks again View attachment 18491 View attachment 18492
  7. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    These will work for a 10b and a 60 I believe. They will work with a 44 too you just have to mod them in some way. I don't remember what? Check the part # thread for 44 owners.
  8. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    I just bought extended lines from skyjacker, And forgot to tell them i swaped from 10 bolt to dana44. Now the banjo bolt is to big for the fittings.
  9. NoReGrEtS
    Nov 7, 2005
    848
    Brake lines are $36 and they are 25-7/8 long.
    The steering arm was a b!tch but a bfh work best
    thanks again
  10. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Hey, your truck looks like mine.
    Try this for removing the steering arm. Take a min 3lb sledge and wack the arm straight down as hard as you can on the "Numbers" that are cast into the top of the arm, near the steering box end. I originally tried for 2 hours beating it every way I could then someone told me about the numbers and it only took 2 hits :bow:
    __________________
  11. ballu_one
    ballu_one Registered Member
    Mar 13, 2006
    20
    ont. canada
    i use a big mo fo .
    id do some blow and work all night on the truck thats what like to do so see ya got a beer in one hand a pipe in the other ,
  12. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    uh oh..we got a crack head on the board and it sound like he has been up for a few. GO TO SLEEP.
  13. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    you should check out his other posts - i don't think the guy has said even one thing that makes any sense or is of any value. wierd stuff too.
  14. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,015
    848
    Pinckney, MI
    This place has been fillin up with monkey lately
    but big hammer, and Pb blaster and a few beers
  15. NoReGrEtS
    Nov 7, 2005
    848
    hey thanks for the tip
    WTF!!!!!!
