In Truck weld question
Discussion in 'The Garage' started by Jemaddux, Oct 28, 2005.
  1. Jemaddux
    Jemaddux Registered Member
    Dec 30, 2004
    76
    F@@k OFF
    :confused: :confused:
  2. botboy
    botboy 1/2 ton status
    Aug 11, 2004
    225
    Delano, MN, USA
    http://www.speedyoldtruck.com/images/rangerpic.jpg
    http://www.speedyoldtruck.com/images/dodgetrailer1.jpg
    http://www.speedyoldtruck.com/images/dodgetrailer2.jpg
    Friend gave me the remains of a '95 Dodge 1500 LWB....so I started turning it into a custom welding & fabrication trailer like I had intended to do with some scrap steel & extra axles I had lying around. Way better IMHO than one of those alternator based systems, and it can run 120/240VAC equipment too.
    Now I just gotta wait for the gas air compressor I just bought to arrive and I'll be set...
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Here is a post about mine.I made it myself.The pics dont work but I will get them up later.
  4. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    This is a shackle I had to weld with it on the first day of a four day trip.
  5. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    This part?
    This is the control box.It has the positive and negative hookups for the leads,on off switch and indicator light,and the volt gauge I picked up used at an electrical supply place. :D
    Chris
  6. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I made that box out of some junk I had.That box is realy nothing more than a place to tie together your wires and mount all of your stuff.There realy is no control per say.The on off switch energizes the field on the alt and you control voltage with engine RPM.The You could use any sort of metal box.Hell,you wouldnt even need to use a box realy.You could just make a plate or sort of panel to hook everything to if ya wanted.
