inacurate gas gauge
Discussion in 'The Garage' started by chsblazer84, Nov 14, 2005.
  1. chsblazer84
    chsblazer84 Registered Member
    Sep 13, 2005
    6
    Roswell
    im not sure if this is just specific to my blazer but i have an 84 k5 and i think im havin trouble with the gas gauge. whenever i fill up the needle never goes all the way to full and sometimes doesnt make it past the 3/4 tank mark. normally i wouldnt care about something as minute as this but its a little disconcerting because i dunno if whens its on empty if its really empty or not. also whenever its on empty and i fill up it seems like i only put about 20 gallons in it each time. just wonderin if this is common or just my problem. some tips on fixin it would be apprecaited. thanks.
  2. kp texan
    kp texan 1/2 ton status
    Sep 8, 2003
    211
    Corpus Christi, TX
    On my '88 K5, I had a similar problem. The gas gauge would read full but as the gas gauge went down it would go no lower than the 3/8 mark. I dropped the tank and found out that tank baffle had broken off and was stopping the sender float from going all the way down. Since your K5 is an '84, though, I don't know if you have a baffle in the tank since you're carbed. In that case I guess your sender may need to be cleaned or something else could be stopping the float from going all the way down. Good luck, maybe some of the guys with more experience can help you out.
    -Wes
  3. 84blazin
    84blazin 1/2 ton status
    Nov 9, 2004
    345
    Queen Creek AZ
    Be happy your goes up to 3/4 of a tank. :D I have an 84' also and when full only goes up to "just above" 1/4 tank.. :haha: :haha: Might need a sending unit.
  4. lrazer
    lrazer 1/2 ton status
    Oct 3, 2004
    231
    Mokena, IL
    i got the same type of problem on mine sometimes the gage is acurate sometimes its not it could b at 3/4 one minute then half the next it usuallt is accurate to within 1/4 of a tank (which isn't very accurate at all) don't really know what causes it or what needs to be replaced/repaired to fix it, never really cares enough to get into it have had to just make sure i keep it full
    if anyone knows what causes this i would also like to know
  5. natehate
    natehate Registered Member
    Sep 15, 2005
    56
    onterrible canada
    looks like i lucked out
    when i fill up my needle goes like a "1/4" tank past full
    and when i hit e the party is OVER
  6. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
    Its a blazer thing, I have a 91 tank with gage problems too. I fill it up and its fine till it get just below half and out of nowhere it'll be on E :eek1:
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Its not linear , it goes faster from 1/2 to empty due to what it is and how it works :D
    Mine works from past F to right on E , and it does go faster from 1/2 to E :D:D
  8. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I thought that this issue and the fix for it was common knowledge?? 7 other posts and 66 views, yet no one replied??:doah:
    Any way, that is casued by the cyrstal being cracked or damaged in the back of the fuel gauge. Usually casued by vibration over the years.
    You have two choices, and neither of them are related to your sending unit.
    1. Change out the entire gas gauge.
    2. Replace the crystal. You can get a kit from Fix-A-Gauge for around $8-$10 that will do the trick.
    I just put a 79 gauge in my 87 and other than the different looks, it is perfect now.
  9. lrazer
    Oct 3, 2004
    231
    Mokena, IL
    i just looked on fix-a-gauge's site
    Q.: How do I know my fuel gauge is broken?
    Ans.:
    Fuel will indicate 1/4 of a tank when full. The needle will not move until tank is under 1/4 of a tank.
    this does not seem to be the problem here or is this not the only way the gauge can be broken?
  10. readymix
    May 30, 2004
    6,706
    26
    You said...
    I was replying to....
    How is that not the same issue
  11. lrazer
    Oct 3, 2004
    231
    Mokena, IL
    yea sorry i just realized that, i was about to edit it
    i was thinking it was all the same issue
  12. readymix
    May 30, 2004
    6,706
    26
    All good.
    I was going to get that kit fom Fix-A-Gauge, but i have so many spare gauges laying around here, I just used one of them....
  13. MTChevy
    MTChevy 3/4 ton status Premium Member
    May 6, 2005
    7,141
    78
    Great Falls, MT
    mine is the exact same way...
  14. botboy
    botboy 1/2 ton status
    Aug 11, 2004
    225
    Delano, MN, USA
    My dad has the same problem with his '89 V3500 crew...except, it has saddle tanks and does the same thing on both tanks! I think it's a gauge problem, have a new cluster to install just haven't gotten around to it yet...
  15. readymix
    May 30, 2004
    6,706
    26
    Mine has a saddle tank too, as it is a truck.
