Inboarding shocks, where to place mount on axle
Discussion in 'The Garage' started by 85mudblazin, Sep 11, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I am going to be inboarding my shocks, I dont want the mount on top of the axle, I want to put it on the sides so it helps with axle wrap a little bit, would it be ebtter to but it in the rear or in the front of the axle??
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The best is the staggered arrangement like the factory. Only problem is you'll likely have to build two crossmembers to pull it off.
  3. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yea I dont really want to have them staggered I think either one side or the other, do you think it will really make a difference which side it is on??
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I don't think so, but I'm not really the one to ask because I haven't inboarded mine yet.
    Hmm...maybe I'll actually do that tomorrow.
  5. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    Having the shocks staggerd helps reduce brake hop and axle hop. I would try and stagger them. Or add 2 more and have 2 on both sides. /forums/images/graemlins/truck.gif
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Ill probably do that, I think I can make the cross memeber out of 2" square and mount one shock in each side and it will still work, I HOPE!!.
    -Chris
  7. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    the best way is to get the shock as far out as possible. I was gonna run my own kit ont he rear but after routing new exhuast and building an anti wrap bar I ran out of room for inboarded shocks so mine are built off my spring plates and angle back to some custom hoops.
    If you want them angled in and front to back for wrap control I'd go with 2 pointed forward and pointed back.
  8. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    Here is where ours end up.
  9. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    You must be bottoming out on your shocks, not the stops.
  10. 85m1009
    Jul 11, 2000
    718
    Missouri
    I do not bottom out with the springs I have. I cycled it with a fork lift and ran several trails in Colorado this summer without bottoming out the shock. I reused my existing shocks and if need be I can move the shock inward or go to a shorter shock. With lift springs there is usually a whole lot more down travel than up. /forums/images/graemlins/waytogo.gif
  11. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    sorry for the hijack
    so if i already have your weld on shock tabs, i cant use the axel truss? [​IMG]
  12. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    thats where I was going to put mine but they wont do jack for axle wrap.
  13. 85m1009
    Jul 11, 2000
    718
    Missouri
    Yes you can. It will stop just inside of the shock mounts or you can remove them and we can make the truss wider and re-attach the mounts to the truss.
