Increasing front brake hose size opinions *DELETED*
Discussion in 'The Garage' started by 84_Chevy_K10, Sep 27, 2004.
  1. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Post deleted by 84_Chevy_K10
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Re: Increasing front brake hose size opinions
    Brake pressure is a function of the caliper pistons resistance to movement, not the resistance of the lines. I think the main reasons manufacturers use small lines is because of cost and a smaller line is easier to route, not to create pressure in the system, and since there is very little flow in a brake system, a larger line is not needed. In short, you will be ok.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I might order up some fittings and go for it then. /forums/images/graemlins/smile.gif Thanks.
  4. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    You guys played nice this time, that makes me so happy /forums/images/graemlins/laugh.gif /forums/images/graemlins/rotfl.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    We talk almost every day on AIM. Tyler's not a bad guy we just rarely agree on something that isn't technical.
  6. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Line size doesn't matter... it's the piston size on each end of the line.
    I think they use small lines because then they can get more fluid displacement and get fluid out of the hot caliper. I could just be imagining this too.
    I, personally, like those 25" long ones off IFS 1 tons.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    These are 40".
  8. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    holy crap, are these the hydralic hoses you were talking about or are they really street legal brake hoses??
  9. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Tim I think this might help you out:
    That is all. /forums/images/graemlins/grin.gif
  10. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Tube & hose size does matter, a LOT! In steel tubing there is almost 2.5 square inches more surface area per foot with -4 or 1/4" tubing over -3 or 3/16" tubing. It is nearly 1/3 of another front caliper piston's area. That's a lot more surface area that will deflect. Deflection = mushy pedal. Put your hand on your rubber brakes hose and have a buddy stand on the brake pedal. That should show you that small is good. Going too far and trying 1/8 will not flow enough and cause a delay in brake application.
    Don't use -4 for brakes in passenger vehicles, it's OK for hyd clutches. Bigger trucks, like 5 tons, use 1/4" hoses b/c of the large wheel cylinder volume.
  11. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I didn't write the first part so I don't know what the f' you were thinking.
    Hose diameter only matters outside of reason. It's the length of the hose that matters more. If your hard lines expand any noteworthy amount you have issues. If you're using crappy hoses (such as most cheap wannabe stainless braided ones) then get some stock ones.
    Flow is more related to stroke and bore of the master cylinder.
    I, personally, believe that it is more important to keep the hose short than the diameter small. I don't know anyone that has the 40" of wheel travel that a 25" long IFS Chevy hose can support.
  12. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Increasing the diameter will cause the system to need and move a larger volume of fluid. I question the master cylinders ability to keep up with the demand.
    My bet is this will cause a mushy pedal with poor performance, if any at all.
  13. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I went through this though process on trying to decide what diameter lines I wanted to run on the Hydro assist setup.
    Now the lines are larger diameter but its a closed system and a hydraulic one at that. I think you will end up with the same means to an end. The fitting off of the hard line is the same and the fitting on the caliper is also the same diameter. In a sealed system like that. I believe it would be just like running a longer brake line. Yu would have to push some more fluid but it works out in the end. Its not like its a fuel delivery system or a loop system of some kind. This is discounting hose expansion under load but if the hose is a quality one, it should be OK.
    I say run it. I dont see how the MC would need more capacity on a closed system like that. Now if you were going to a larger Caliper or something like that, then the MC might become an issue.
  14. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    The slave cylinder moves a set distance...
    The amount of fluid needed to move that set distance doesn't change...
    Therefore the master cylinder need not move any more fluid...
    The only thing that changes is that the fluid in the line physically moves less distance...
    So, in essence, the size of the line between the master and slave cylinder affects the pressure applied to the slave cylinder negligibly. This is assuming that the line between the two doesn't expand. So, the goal is to keep the line as small as possible in order to keep the expansion of the line as small as possible. This is especially true of flexible lines.
    It seems like in my readings years ago I read that brake hose specifications were based on increase in volume per unit pressure. So even though a hose might be larger in diameter it had to meet the same specifications in expansion as a smaller hose.
    Anyway, keep the hoses short. If I were a rich person I'd probably use Earl's Speed-seal ends and Speed-flex hose.
  15. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    [/ QUOTE ]I don't think Tim runs his rig on the street. If you do they are supposed to be D.O.T approved.
  16. BlueBlazer
    Feb 15, 2001
    1,940
    I agree with you and Sandman 100%. Seeing as the line is not the restriction in the system, opening it up would not cause more flow nor a spongy pedal.
  17. BlueBlazer
    Feb 15, 2001
    1,940
    In theory you are correct, but without knowing the actual strength of the line Tim is using, its pretty hard to say that he would get more deflection in his line. I am assuming that the teflon lines he had made are far stronger than a stock rubber line, which would as you know offset the difference in hydraulic force inside the line between sizes.
  18. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    Can you beleive that chevy has a TSB out on corvettes that stainless steel brake lines void the warranty?
    I'd be /forums/images/graemlins/angryfire.gif if I had bought one. GM Make PISSA vehicles IMHO and I wouldn't buy one new if they payed me to take it off the lot (okay, maybe then /forums/images/graemlins/rotfl.gif). Their [dis]service is really disgusting. /forums/images/graemlins/crazy.gif
  19. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Yes, I can, most stainless lines are JUNK.
    The way the aftermarket crimps the ends on those stainless lines is pathetic. Furthermore, most stainless lines are for bling only (some are just rubber regular hoses inside, no teflon) and all the stainless does is look pretty. The only "good" ends for stainless lines I've ever seen are Aeroquip's "super gem" and Earl's stuff.
    I suspect there's a reason why Ferrari doesn't use them either.
    If people are so worried about their brake lines why don't they change their fluid? Most fluid is saturated with water after two years.
    The funny part about those aeroquip or earl's ends is that they CAN'T meet DOT requirements because the ends aren't swaged or crimped on. Even though they're a superior way of fastening.
  20. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    i dont see a problem using hydro line, i had one on my rig for my rear axle.
    comparing side by side nobody here would pick the stock line, it looked pathetic next to the double wall hydro line i replaced it with.
    it may not have been DOT approved, but hell nothing else on the truck was either, and the rig didnt see a lot of road miles.
