Indexing pitman arm for X over?
Discussion in 'The Garage' started by stallion85, Jul 25, 2004.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Tomorrow I am starting on my front axle swap. I scored a D44 with ARB locker, ORD Xover, Chrom moly shafts,CTM ujoints, Rockstomper tie rod, and Rock Stomper diff gaurd. Sweet setup. Well I have to change the ring gear out also due to chipped teeth. I have a R&P and install kit. My Dad is helping me the R&P install. Once that is done I am taking the old D44 off and putting the new one up. I have a 2wd steering box and the ORD pitman arm. I am going to replace the sector shafts and continue to use the box I have on there now. I however do not have the nut that goes on the 2wd shaft? Does anyone know what size it is? I hope i can pick it up from a hardware store.... Anyways as long as I have the steering wheel straight when I park the K5 i should be able to moun the pitman arm correctly. My question is at what angle is the arm supposed to be indexed with the wheels straight? Thanks for any help and wish me luck. /forums/images/graemlins/whistling.gif
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    withthe wheels pointed straight it should be indexed straight back. There are only 4 points it can be indexed so it's pretty simple. /forums/images/graemlins/waytogo.gif
