Indiglo dash kits for our blazers?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scottnj, Apr 13, 2002.
  1. scottnj
    scottnj 1/2 ton status
    Aug 4, 2001
    112
    Central Florida
    Has anyone seen any kits for our k5 type blazer out there.
    Thought it would look pretty cool.
    I See they had the new style brake light lenes for our k5's now. Was thinking maybe someone has seen the indiglo kits somewhere too.
    thanks
  2. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    check out my gauges in my signature (on the off-road k5). these are VDO vision series, and these things light up like craze at night. I've never seen a set of gauges that look as good at night time as these things do.
  3. blazen_md
    blazen_md 1/2 ton status
    Aug 20, 2001
    129
    MD
    how hard was it to put in the vdo gauges and do they make a kit for this?? or did u just buy each individual gauge?
  4. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    Here's another option for gauges.... A TAD pricey, but most unusual!
    <a target="_blank" href=http://www.dakotadigital.com/Detail.cfm?Category=82&amp;PartNumber=STR6D-73C-PU>http://www.dakotadigital.com/Detail.cfm?Category=82&amp;PartNumber=STR6D-73C-PU</a>
  5. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    as long as you own a dremel or a air cutter it is a piece of cake. if you decide to make your own wiring harness it is a bit time consuming, but painless wiring makes one for $50. I have a parts list if you are interested;
    Note: all of the part numbers are summit racing part numbers and can be looked up / ordered on their web page. The part numbers on VDO's web page would be the first 3 digits followed by a space and then the last 3 digits.
    VDO-333160 - Tachometer
    VDO-301106 - Fuel gauge for GM sender
    VDO-332103 - Voltmeter
    VDO-350107 - Oil Pressure
    VDO-310105 - Temp Gauge
    VDO-437155 - Speedometer
    VDO-323900 - Temp Gauge Sender Unit
    VDO-360900 - Oil Pressure Sender Unit
    VDO-340011 - Speedometer Sender Unit
