Individual Runner intake manifolds - need to know runner length
Discussion in 'The Garage' started by Twiz, May 14, 2003.
  1. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    K
    Buddy of mine is building a Hemi for his '32.
    He wants to run a I/R manifold, 8 individual intake runners leading to 8 single barrel carbs. I've done some research on this set-up, and "get" the theory, could still use some help with it tho'. *Any and all info, would be helpfull*
    We are looking for the formula - to find the correct dia and length of runners for the RPM/cam, ect...
    Any input would be helpfull!!!!!!!!
    ( TPI guys might wanna check this out too, as this is the "tuned" part of TPI )
  2. dyeager535
    26,980
    Stock TPI runners are about 17-19" IIRC. Which is also why the engines make a good deal of low end power, and are limited at about 5000RPM with stock runners.
    I've got a TBI intake in the garage. Want me to measure the runners?
  3. Sledge
    Sledge Registered Member
    Feb 24, 2000
    75
    Reno, NV
    David Vizard has some pretty good stuff about helmholtz resonance in his intake manifolds book. I don't know what you're looking for, but that might be worth checking out.
  4. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Agreed
    David Vizard goes into detail on the subject in a couple of books, I might add, for anyone interested, VERY excelent reading. I've also found a "Desk Top Dyno" book that allso goes into detail. But, unfortunetly, no formulas.
    So far, an artical by David Vizard is all I've been able to find that actualy inculdes formulas for figureing out the intake runner length.
    Intake Pulse Tuning
    Thats what I'm looking for, but I'd really like to find as much information as I can get, formulas, design, funtion - anything !
    Thanks guys.
  5. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    I have done alot of reading on this subject. Here is what I am told. You need to know what lift your cam is and the valve size? You get the valve curtain in square inch area. The inlet to the manifold should be the same square inch area as your valve curtain. Next you should find the smallest square inch area of the intake port. On a hemi that should be at the mounting surface where the manifold bolts to the heads. Now the runner should taper from the smallest square inch area to the largest at a 1.5-3 degree taper. That should answer your question. Let me know if you need anything else.
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    8 carbs? He also wears black leathers and frequently says, "yes mistress" right? /forums/images/graemlins/rotfl.gif
    I nearly pulled my hair out running 3 dueces on a 455 '66 GTO daily driver just trying to keep them all running right, and that was depending on one as a primary! /forums/images/graemlins/tongue.gif Course they were old patched up rebuilds, but still, 8 carbs? I would tell him to just stick to seeing a 'trix... /forums/images/graemlins/rotfl.gif
    Sorry, no help here, way over my head...
  7. Sledge
    Feb 24, 2000
    75
    Reno, NV
    Twiz,
    That article looks to be the same as is in his "carbs and intake manifolds" book. I like his explainations, but I think he falls back on "wet thumb" engineering at times -- too many generalizations/hueristics instead of formulae. It is good stuff though! He's certainly the most "scientific" author I've read outside of SAE papers.
    Have you seen is book on the British Leyland A-series engine? It is motor-specific but has a lot of good generally-applicable theory.
    Once upon a time we were starting to a custom intake manifold. We planned to build it in 3 pieces: mounting flanges at the top and bottom with a removable velocity-stack-thing in the middle. That way we could get "close" with the formulae and fine-tune it by swapping in different length stacks w/ the engine on the dyno.
    This was an all-out effort with a very narrow target RPM range. I don't know if it would be worth the effort in your application. It's always fun to play though! /forums/images/graemlins/smile.gif
